Author Topic: starter for 10, who knows what these black round rubbery bits are? - A. liftpads  (Read 22691 times)
Offline Teutonic_Tamer
Silly question but why did you have 10  :smug:
It took me ages to work out what you are on about!  :rolleyes:
Anyway, no, I don't have 10.  Don't you watch the BBC2 quiz show called "University Challenge"?  The question master askes the first question, (as a single effort without conferring, to be answered by the buzzer) - and this is reffered to as a "starter question" - and he commonly says sommat like "fingers on buzzers, here is your first starter for ten".  Answered correctly, they get 10 points - hence my attempt at whit!  :tongue:
And there was I, thinking everyone knew about University Challenge . . . .  :rolleyes:
I feel like a homo
Offline Top Cat
Ah no i got that bit of the joke i even laughed dont you know. Embarrassingly i miss counted because your pics are so big i had to scroll across the screen and believe it or not added up the amount wrong.   :grin: :embarassed:
Offline Sootchucker
They are lift pads.
bacillus was correct, though I'd like to know how he new, because none of my local stealers could ever find the part numbers for them!
Anyhow, front:
and rear (and look at all that lovely gloop  :wink:):
TT, sorry to drag up an old thread, but I've just ordered some of these from my local Audi dealer. I thought I would see how the fornt ones fit, but try as I might, I couldn't get the circular(ish) access piece on the undertray off ? It would spin through 360 degrees, but would pop up, and just bent when I tried to lever it off. Were your's that difficult to remove ?
Also, if I can get the part off and the lift pad fitted, can the access panel be refitted with the lift pad still in place ?
Offline stokeballoon
Just give it a good tug, it will give in the end.
And no you can't reuse the covers when the pads are in.
Offline BBHARVII
I've got a golf mk5 1.6 2006, I'm in the UK do I order them from the dealers :shocked:? How much and what do I ask for :rolleyes:?
Thank you! :smiley:
Panthera
Ooops - the part numbers!  You need four of both.
8N0 804 583 - lift pad rubbers, retail £1.15 each
8N0 803 855 - lift pad hard inserts, retail £2.35 each
In my best Bamber Gascoine accent - 'cause Paxman just aint got it -
A starter for 10, who knows what these black round rubbery and nylon bits are?
They are lift pads.
Anyhow, front:
Are these VW parts or Audi parts???
