Author Topic: A Reasonable Oil Temperature  (Read 1228 times)
Offline drivebycar
« on: 21 October 2008, 09:18 »
What would a reasonable oil temperature be on the dash, when caning ones car? And at what point should one slow down a bit?
Normal is getting dressed in clothes that you buy for work and driving through traffic in a car that you are still paying for - in order to get to the job you need to pay for the clothes and the car, and the house you leave vacant all day so you can afford to live in it.
Offline Horney
Re: A Reasonable Oil Temperature
« Reply #1 on: 21 October 2008, 09:19 »
up to 120 is OK, start getting worried above that.
Nick
Offline JC
  • Back in the North.
« Reply #2 on: 21 October 2008, 12:11 »
 :grin: do a search, LOADS of threads on this, highest mine got was 132  :shocked:
Offline edpryce
« Reply #3 on: 21 October 2008, 12:36 »
i was waiting for a temperature thread. As the ones in the search aren't specific enough for my question.
Seen a few questions about peoples cars not heating up enough, and quite a few responses saying replacing the thermostat is the answer.
When cruising on the motorway 70 give or take a few 10mph, my temperature is really low, just between the bottom line and the bulb? is this too low? oil is around 100.
The thermostat rises to about 3/4 in traffic (which seems normal, and would suggest it is working) and then the fan comes on and it prevents it getting higher.
Having never had a thermostat on a car before, is it normal to be this low on the motorway? I figure the faster you go (to an extent) taking it easy in 5th, wont cause the engine much stress, and there is a lot of air flowing over the engine, cooling it. should I be worried about operating temps etc?
its been a while since anything broke, probably just looking for problems.
cheers
Offline Horney
« Reply #4 on: 21 October 2008, 12:38 »
Sounds like your stat is stuck open. Mine was in my Rado when I got it and had the same symptoms. New stat and O ring from VW sorted it a treat.
nick
Offline edpryce
« Reply #5 on: 21 October 2008, 13:30 »
thanks
will it be damagaing it as it is? Or is it just irritating?
i can live with irritating
Offline sidecarphil
« Reply #6 on: 21 October 2008, 14:36 »
i used to race sidecar and we were always told by the oil freek specialist's that your oil work's best between temp's of 70 to 115 c :) above that it start's to loose it's lubricating property's or summet like that i just nodded politely and screemed off out the paddock on the sidecar  :rolleyes:
but wi had data logging on the bike and the oil temp's were about 110 c during the race so i guess that was ok as we never blew any moto'rs up and i reved them to 14,000 :)
well till we changed to the latest RR honda motor (swear it was made of chocolate) but that is another story :huh:
« Reply #7 on: 21 October 2008, 14:51 »
there is a coolant faq which covers checking the coolant system for faults :)
Offline edpryce
« Reply #8 on: 21 October 2008, 16:13 »
cheers. Once again i owe you
