Author Topic: High temp light flashing  (Read 995 times)
Offline dubsport
  • TDI POWAR!
« on: 20 October 2008, 17:21 »
hey,
changed the oil pressure switches today and that has stopped the oil light flashing/buzzing (although the wire going to the bottom switch was broken so it was probably just that ... its always the simple things you dont think to check)
However, the high temp light still keeps flashing - about 15 seconds after i start the car up ... could this be one of the senders? what else could it be?
thanks
Offline Mr Blue
Re: High temp light flashing
« Reply #1 on: 20 October 2008, 18:16 »
check your coolant level
Offline dubsport
  • TDI POWAR!
« Reply #2 on: 20 October 2008, 18:51 »
coolant level is spot on *scratches head*
Offline Conker
« Reply #3 on: 20 October 2008, 19:17 »
Theres loads of threads already that can help you with this. Tank sensor, wiring, clocks, etc. etc.
Offline dubsport
  • TDI POWAR!
« Reply #4 on: 21 October 2008, 15:19 »
there is a single wire souldered onto the back of the (new) clocks that isnt on the ones i took out, bloke at work seems to think they have earthed it or something?  :huh:
