Author Topic: JKM TFSI K04 Conversion Dyno Results  (Read 18910 times)
WhiteGTI
Re: JKM TFSI K04 Conversion Dyno Results
« Reply #30 on: 20 October 2008, 22:54 »
I phoned them the other day, and they told me that the APR pump is of superior design and quality to the Autotech and KMD.
They said that sometimes you get good examples of KMD's / Autotech's, and sometimes you can get bad ones. But the APR's quality is second to none. They said that the design of the APR pump is very similar to the stock part - simple and very effective, but of all round a much better quality.
But then again, it is a lot more expensive!!
This probably doesn't help this discussion, but thought I would post what I know  :smiley:
Offline Hurdy
« Reply #31 on: 21 October 2008, 00:15 »
Their sudden move towards APR doesn't surprise me. A ready made pump sealed and ready to go will make it easier to fit and save time and effort on JKM's side.
I'd still like some clarification on the true reason behind the shift though. :smiley:
Seat Leon Cupra Black 290 DSG
Offline neg
« Reply #32 on: 21 October 2008, 01:03 »
If I get some spare cash lying about I could be tempted - at least I can then look to keep the car until the new GTI-R is realeased and on the roads which is going to be another year or so I suppose... Mmmmm, lets see whats left in the kitty once the house is done  :rolleyes:
Offline E30M3
« Reply #33 on: 21 October 2008, 01:20 »
6 big ones !!! you might aswell get an ED30 !  :laugh:
[/URL]
Offline Vtec Abuser
« Reply #34 on: 21 October 2008, 08:45 »
Exactly, you could sell your GTI, buy a ED30, mod that and STILL have change...  :grin:
Or probably even buy an S3.. :shocked:
Candy White Ed30 3dr DSG, Nav, Bi-Xenons, Armrest, MFSW...
Offline neg
« Reply #35 on: 21 October 2008, 09:23 »
My GTI is fully loaded and I would expect a sway to an ED30 would be around £5k when a K04 conversion would be around £3k as I have Stage 2 mods already
Offline Vtec Abuser
« Reply #36 on: 21 October 2008, 09:26 »
But the residuals on the Ed30 would be a lot better mate and you would also have the ED30 spec to go with it. 3k isn't THAT bad really, but 6k is..  :shocked:
Offline neg
« Reply #37 on: 21 October 2008, 09:37 »
I see your point - would need xenons though  :cool:
Anyway, house project first and then could be tempted with a mk6 anyway as I will be due for a swap about then (bearing in mind DINK is going out the window early next year)
Offline JKM_Performance
  • www.jkm.org.uk
« Reply #38 on: 21 October 2008, 10:25 »
JKM appreciate that some people would like to know more about why we have made the switch from KMD & Autotech TFSI fuel pump internals, over to the complete APR pre built and tested unit.
Where we have been using KMD/Autotech internals I will detail what process we have been going through for each fuel pump prior to sending it out to a customer, so you will get a feel for the process that needs to be run through by JKM to ensure that the pumps are of sufficiently high quality to sell to a customer.
After receiving the fuel pump internals from the manufacture (say for example KMD) we first check the machined parts for known manufacturing problems by measuring and a general visual inspection – any problems here and the pump internals are rejected.
We then hand assemble the parts together and with a light lubrication between the piston and bore, the clearance and general feel is assessed. The internals are then hand assembled into a test fuel pump body - any problems here and the pump internals are rejected.
Assuming that all is good on the above, we can then begin an up rated fuel pump internal build into a brand new OEM pump.
Cleanliness is paramount here as any debris etc will ruin the piston shaft. This is something that we only do in an extremely clean environment to ensure the utmost quality.
Once the fuel pump is built, we then move onto the next main step – Testing.
To ensure that each TFSI fuel pump that we supply is of the highest quality we have been testing each pump built by JKM, on our own TFSI car.
Therefore every time we build a new pump Kates nice new shiny Mk5 GTI is pulled apart and the test pump is installed for performance testing under load. Following the install we analyse each fuel pump in detail.
We will look at the fuel pumps Quantity Valve differential angle, Total Compression volume, Fuel pressure and more – again comparing the results against known good units.
With our experience of these pumps it is possible to analyse the results and detect possible problems with internal clearances as a result of machining tolerances, but this is a very complex area. If we suspect problems we will remove the fuel pump, disassemble and inspect it again – any problems found here and the pump internals are rejected.
Following all of the above, assuming that the built TFSI fuel pump is functioning correctly, we will remove the fuel pump from our test car, seal it into a bag and box it and send out to the customer.
The main reason we have chosen to swap from KMD/Autotech is that the above is very costly to us (time wise) to get a good pump together. We have sometimes had to build 3 pumps to get 1 good unit.
We appreciate quality engineering, which APR provide with their fuel pump,
Our equivalent of the APR test rig, is our own MK5 Golf GTI engine and our diagnostics knowledge.
APR does have a superior hardware design, changing much more than just the piston and bore. The complete internals are re-engineered, right down to the balanced seal rings and main spring assembly. This design puts less stress on the rear balanced seal than the other pump solutions – the APR pump design is along the same route as the OEM pump only obviously containing larger internals for increased fuel volume.
APR route out bad pumps themselves during testing at their own facility, and the pumps have even been used by VW Motorsport on the VW Scirocco GT24 which won the ADAC 24h Race without any fault.
For those interested more information on this can be found here: http://forums.vwvortex.com/zerothread?id=3855643
JKM will only bring to market the quality items. If we find that the quality of an item is not acceptable we will first try and work with the supplier for a solution but ultimately if we would not be happy to use the product on our own car we will not sell it to a customer for use on their car.
For JKM the up rated internals route (only) is too inconsistent from the manufacturers.
APR provide a quality fuel pump out of the box, and the customer is in the knowledge that there will be no issues.
The APR pump can be bought in 2 ways; we will be updating our website shortly to include the cheaper core exchange route.
1) An outright buy of an APR pump, where by you can remove your stock TFSI pump and retain it somewhere safe and simply install the APR pump. This route costs £624+Vat excluding postage back to you.
2) The second route is a core exchange, where by if you send us your TFSI pump we will send it to APR for a pre built unit, this route costs £509+Vat excluding postage back to you and you are responsible for postage of your pump to JKM intially.
For those customers already with a JKM built KMD or Autotech pump, you do not need to worry as we have done the above testing process on your pump to ensure you have a good unit. I hope this helps clear up the questions in this area and hopefully you will appreciate why we have made the switch to the APR unit.
For those who wondered, our own car does use an APR fuel pump but the K04 conversion car that has been on long term testing (20,000 miles) has been, and is still using a KMD pump without fault.
JKM
JKM Motor Services Ltd Based in Portsmouth, Hampshire, Phone 023 9263 9933 – Monday to Friday 8:30am to 5:30pm. VAG Servicing, Diagnostics, Rolling road Testing & Tuning, Online Webshop & mail order. 2.0 TFSI Specialists - Revo - Superchips – Bluefin – Milltek - Koni - Forge - Green Cotton - Eibach- Tarox - Ferodo – Emerald ECU’s + much more! www.jkm.org.uk
Offline RedRobin
« Reply #39 on: 21 October 2008, 10:53 »
High quality info, JKM!! :smiley: :smiley: :smiley: :smiley: :smiley: - Five Star Quality!
