Author Topic: G60 gearbox?  (Read 2306 times)
Offline euro dave
G60 gearbox?
« on: 17 October 2008, 21:53 »
Hi,
Can anyone shed some light on why the G60 gearbox is better than a normal mk2 box?  Do they have stronger internals or shorter ratios?
Offline Jay
  • balding fat cvnt
Re: G60 gearbox?
« Reply #1 on: 17 October 2008, 22:33 »
Not sure about the ratios, although they won't be the same as a normal MK2 'box.
The internals are stronger so they can handle the extra power.
Offline Organisys
  • Old and Slow...
Re: G60 gearbox?
« Reply #2 on: 17 October 2008, 22:57 »
Much stronger (fingers crossed) and are cable change rather than rod change.
Offline Diamond Hell
  • Opinions я Us
Re: G60 gearbox?
« Reply #3 on: 17 October 2008, 23:18 »
It's the cable-changeness of it wot means it's a lot stronger - it's a much different gearbox - much heavier vs the rod-changer.
These boxes can be found in anything from 2.0 8V Passats to Toledo 16Vs.... although the ratios will vary.
Offline Khare
  • The bear that khares
Re: G60 gearbox?
« Reply #4 on: 17 October 2008, 23:19 »
say i want a short ration box for my 1.6. What donor car would i need to tackle? toledo 16v or passat?
Offline danny_p
Re: G60 gearbox?
« Reply #5 on: 18 October 2008, 00:53 »
mk2 gti box, and transform a golf driver.   if you want lower  a mk2 16v box  (lower 5th )    if thats not enough a 1600 mk1 gti box. and if thats not low enough ring and pinion set out of a blown up syncro box.
all the VW's have gone bar 1.
Offline Khare
Re: G60 gearbox?
« Reply #6 on: 18 October 2008, 10:53 »
mk2 16v box sounds pretty good. But what if i wanted low ratio's 1-4 and a very long 5th for economical motorway driving?
Offline danny_p
Re: G60 gearbox?
« Reply #7 on: 18 October 2008, 11:17 »
thats the gearbox you have now,   unless you swap 5th and do a  hybrid box
Offline Khare
Re: G60 gearbox?
« Reply #8 on: 18 October 2008, 11:27 »
oh so what ive got now has low ratios 1 to 4 and a long 5th? cos when doing 70 on the m'way its noisy as hell (cant see revs cos ive got the big ben)
Offline euro dave
Re: G60 gearbox?
« Reply #9 on: 18 October 2008, 13:06 »
Cheers for the info - I'd seen one for sale with the G60 box and that got me wondering!
