Author Topic: later indicator stalk  (Read 1188 times)
Offline lowmk1
« on: 14 October 2008, 17:09 »
will a later indicator stalk fit my early type with hazzard on the dash? :smiley:
Offline Neaty
Re: later indicator stalk
« Reply #1 on: 14 October 2008, 17:32 »
When I snapped mine on my H reg (91) driver, I got an indicator stalk from a late Mk2 (wasn't told what year) and that didn't fit. I think unless you can get one from the same year as yours then it won't fit.
Just noticed you are from Preston, where abouts?
« Reply #2 on: 15 October 2008, 11:11 »
lowmk1: it wont bolt on or plug into your loom, the column outer tube and ign lock housing is different.  You can swap the column tube over if you're good with spanners, and splice the stalk & ign switch wires if you're good at electrics :)
neaty: it must have been a pre90 one, all MK2 stalks after 1990 are the same.
Offline Neaty
« Reply #3 on: 15 October 2008, 12:30 »
ah, the numpty at the salvage place must have given me the wrong one.
Offline lowmk1
« Reply #4 on: 15 October 2008, 17:48 »
argh right, cool!! thanks fo the replys, good job i didnt get a last min bid in then for £15 :nerd:
Neaty im from penwortham, you?
Offline Neaty
« Reply #5 on: 15 October 2008, 18:04 »
Fulwood, near Asda
but in Liverpool at the moment for Uni, so just a bit further up the A59 from you  :grin:
