Author Topic: Explain vagcom pls  (Read 4185 times)
Offline badboy22
Explain vagcom pls
« on: 13 October 2008, 19:10 »
Dont really know what it is been reading some post here and i take it you plug it to your car and reads codes? my airbag light is on my car if i bought this http://cgi.ebay.co.uk/VAG-COM-USB-VW-Audi-Car-Diagnostic-Code-Reader-OBD-2_W0QQitemZ200262764890QQcmdZViewItem?hash=item200262764890&_trkparms=72%3A1301|39%3A1|66%3A2|65%3A12|240%3A1308&_trksid=p3286.c0.m14  will it tell me the fault and also clear the light? i have a mk4 1998 but has 2002 engine in it.In another words does it work as a diagnostics machine? sorry im new to this.
Will this one be better? http://cgi.ebay.co.uk/VW-AUDI-SEAT-SKODA-DIAGNOSTIC-USB-CABLE-VAG-COM-409-1_W0QQitemZ110295833052QQcmdZViewItem?hash=item110295833052&_trkparms=72%3A1301|39%3A1|66%3A2|65%3A12|240%3A1318&_trksid=p3286.c0.m14
« Last Edit: 13 October 2008, 19:15 by badboy22 »
Offline richw911
Re: Explain vagcom pls
« Reply #1 on: 13 October 2008, 20:55 »
Everything you could ever what to know is here:
http://www.ross-tech.com/vag-com/vag-com-faq.html
Offline Ant1981
  • Feed me, prod me
« Reply #2 on: 13 October 2008, 21:44 »
Are any of the above products ones to go for?
'09 Kawasaki Ninja ZX-6R
Offline linz
  • vee-dub
« Reply #3 on: 13 October 2008, 21:49 »
depends some people have bought the cheap ones for about 30 quid and can get a reading from them but honestly the original ross tech one is by far the best
Offline badboy22
« Reply #4 on: 13 October 2008, 22:02 »
But if all you want to do is reset the airbag light then surely not worth paying so much more?
Offline richw911
« Reply #5 on: 13 October 2008, 22:08 »
If you only want it to reset the light and read/reset fault codes get one of these:
http://cgi.ebay.co.uk/U281-VW-AUDI-SEAT-SKODA-CAN-BUS-OBD2-VAG-CODE-SCANNER_W0QQitemZ320309610730QQcmdZViewItem?hash=item320309610730&_trkparms=72%3A1121%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Not a patch on vag com but still good. You WONT be able to change any settings ETC like vag com.
Offline Ant1981
  • Feed me, prod me
« Reply #6 on: 13 October 2008, 22:30 »
So the two above will change settings?
Offline richw911
« Reply #7 on: 13 October 2008, 22:34 »
With a vag com lead and a laptop you can do allsorts of things like:
Enable anti hijack, one touch open, Alarm beep when lock/unlock, data logging ,  throttle body alignment to name a few.
As well as faut code reading clearing reset dash light etc.  :smiley:
Offline Ant1981
  • Feed me, prod me
« Reply #8 on: 13 October 2008, 22:36 »
Oh right, so if I bought that then I'd be able to start learning about Vag Com and make maybe a few changes. So what's the difference between that and the more expensive stuff?
Offline richw911
« Reply #9 on: 13 October 2008, 22:40 »
Yeah VAG com is the way forward  :wink:
What do you mean more expensive stuff ?
If you mean genuine lead or non genuine lead the non genuine stuff from ebay etc is very hit and miss best to go for genuine lead from here:
http://www.ross-tech.com/products.html
Not cheap but worth it  :wink:
