Author Topic: Cleaning exhaust..  (Read 9855 times)
Offline cняis
Re: Cleaning exhaust..
« Reply #10 on: 14 October 2008, 23:22 »
hmmm
must give my powerflow oval exit a polish... its gone a funny brown colour  :huh:
all that 8v powaz and shiz no doubt
Jkctr
« Reply #11 on: 15 October 2008, 09:37 »
Offline admc6
« Reply #12 on: 16 October 2008, 14:22 »
I could just get the brasso out  :laugh:
Offline Cass
« Reply #13 on: 17 October 2008, 00:21 »
Solvol Autosol and a strip of cloth about 2" x 9". Use in a sawing action with plenty elbow grease, especially on the lips :shocked:
Cass
Now: VW Touareg Altitude V6 TDI 3.0 240 bhp, Diamond Pearlescent Black
Previous: MY2007 GTI, 3 door, manual, pearlescent black and lots of toys - gone to a good home : )
Offline Guy
« Reply #14 on: 21 October 2008, 14:57 »
As my exhaust is nowt special, I just use fine wire wool and WD-40, which its looking "good-ish". If you want better:
"Belgom Alu is a liquid cream for polishing alloy, chrome, brass, etc. It is supplied in bottles containing 250mls. Belgom Alu is less abrasive than most other polishes and will not, therefore, remove detail from castings or damage paintwork adjacent to polished areas. White aluminium oxide deposits or other corrosion are dissolved chemically by Belgom Alu - this is far more effective and more gentle than using abrasives. Once the oxidation is dissolved the polish rapidly shines the metal surfaces. At the same time as polishing, Belgom Alu is also laying down a protective wax layer which will prevent moisture or salt spray reaching the metal surface for a considerable time. It is found that in regular winter use a bike may be ridden uncleaned for six weeks or so after polishing with Belgom Alu without metal surfaces corroding."
http://www.elitecarcare.co.uk/product_info.php?cPath=24&products_id=110
Belgom alu FTW!  :cool:
dude - do you not clean inside the zaust?
Cass
sawing action will impart fine scratches on the surface of the metal  :undecided:
Offline AlanD
  • MK5 2.0T 16v
« Reply #15 on: 21 October 2008, 15:11 »
Do Halfords sell wire wool?
Offline Guy
« Reply #16 on: 21 October 2008, 15:31 »
i am trying to think of a joke to do with wire sheep and can't  :sad:
Offline AlanD
  • MK5 2.0T 16v
« Reply #17 on: 21 October 2008, 17:26 »
Try do as I got some on the way home.
Offline stealthwolf
« Reply #18 on: 22 October 2008, 00:10 »
Yes it's in a pack of ten or so.
