Author Topic: Dropped rocker cover bolt into sump.... sump off? oil change?  (Read 4012 times)
Offline Skiing
Re: Dropped rocker cover bolt into sump.... sump off? oil change?
« Reply #10 on: 13 October 2008, 22:17 »
Have ordered magnetic sump plug and will change oil on weekend... hopefully that will get it!
Thanks for your help.
1988 Golf GTi Mk2 16v 2.0 9a bottom end- Oak Green - 3 door - full black factory leather...
Offline 2pac
« Reply #11 on: 13 October 2008, 22:57 »
though you presume it fell down, why don't u try to search for it in the valves chamber? maybe it's under the cam?
Offline Khare
  • The bear that khares
« Reply #12 on: 13 October 2008, 23:03 »
really not meant to say this but a 10mm  nut ratteling round in the sump isn't really going to do a lot.
it can't exactly go up the oil pick up can it  so you be more than unlucky to see a problem from it if it's gone into the sump,   id get a magnetic drain plug and go for a drive that'll grab hold of it at some point
yea hi'd get magnetic dran plug too and give the car an oil change in a few weeks.
Offline danny_p
« Reply #13 on: 14 October 2008, 00:31 »
on an 8valve theer isn't meany places for it to hide,   it's etheer gone down or is pirched round one of the head bolts and sure it would have been found by now if it was.
all the VW's have gone bar 1.
Offline Skiing
« Reply #14 on: 14 October 2008, 09:14 »
Have looked under the cam thoroughly and I saw it fall into the hole...! Anyway will put in magnetic sump thing when it arrives/ jack car up and drain oil and see if it comes out.. will then refill oil, drive home and then change on weekend (by which point hopefully it will have stuck to magnetic sump plug).. hopefully one of these methods will get the buggering thing out...
Offline nealey
« Reply #15 on: 14 October 2008, 21:53 »
Why dont you just whip the sump off and clean out the oil pick up pipe whilst you are there?
Offline monzablue16v
« Reply #16 on: 14 October 2008, 22:45 »
Yeah you don't want it to be rattling around, drop the oil and then use magnet on a stick to fish around for it
Offline Skiing
« Reply #17 on: 14 October 2008, 22:57 »
Will change the oil this weekend and have also ordered a magnetic sump plug. if it still doesnt come out I will take the sump off and find it then...
