Author Topic: Distributor change?  (Read 3426 times)
Re: Distributor change?
« Reply #10 on: 13 October 2008, 10:56 »
I've never had an issue ordering from gsf, as long as you always get the expensive one if given the choice of 2 parts.  Some things should only be bought from VAG though I agree.
Blazing Storm
« Reply #11 on: 13 October 2008, 11:02 »
It was a tie rod end, which rusted straight away and totally split. Also, I had a dizzy cap from GSF where the middle electrode destroyed itself. I'm sure I'm just the unlucky one but it rather puts one off. That's why I now spend more and get genuine VAG parts.
« Reply #12 on: 13 October 2008, 11:10 »
what make was the cap, next time only buy bosch or beru ones ;)
as for rod end they all tend to rust, splitting doesnt sound right though id have taken it back!
Blazing Storm
« Reply #13 on: 13 October 2008, 11:28 »
The point was it had started to rust and had split and the car was still sat in the garage and I hadn't even driven it yet. Just sat there the part withered away over a couple of weeks.
I bought a new cap from VW so all is well.
/thread hijack
« Reply #14 on: 13 October 2008, 11:43 »
yep same here, they arnt coated very well. as i say though, boot still shouldnt split, sounds like it was a badly made one...
Blazing Storm
« Reply #15 on: 13 October 2008, 11:57 »
Speaking of distributors, do you think it could cause rough running/a bad idle if the windows on the distributor catch on the sensor when turning? When turned by hand to took a fair bit of force to turn once it catches.
« Reply #16 on: 13 October 2008, 12:02 »
yeah that would be very bad, time for a new dizzy!
Blazing Storm
« Reply #17 on: 13 October 2008, 12:33 »
Yeah, I bought a new distributor from VW. The mechanic is hopefully fitting it today. Just wondered if the old one would have caused rough running/bad idle etc.
