Author Topic: Fitting new headlights  (Read 5196 times)
Offline stealthwolf
Re: Fitting new headlights
« Reply #10 on: 08 October 2008, 16:33 »
Interestingly, VW now sell official "blue" bulbs, including W5W sides and H7 halogens.  Part numbers and prices available if anyones interested.
Dammit and I've already ordered and fitted the powerbulbs just now.
Can't believe the mainbeams and sidelights aren't as easy to swap as the dipped and indicators. Mainbeam bulbs were difficult to seperate from the connector. Sidelights were frikkin horrendous. I could reach them with my fingers and pull on them but they wouldn't come off! Had to use a bit of jiggly motion (side-side, up-down) to loosen them enough to come away from the sockets. Cut one knuckle and scraped three others (two on each hand). Couldn't grip with pliers.
As stated, sidelights have a blue glass but the light they give off are white. In fact, when I swapped one of the sidelights for the powerbulb one, the original sidelight looked amber (like you get on roads) in comparison! Noticed the difference with the mainbeams too but not so much with the dipped beams. Anyone know why?
Now the lights look clearer, the fogs look too yellow!
Offline joesgti
« Reply #11 on: 08 October 2008, 16:37 »
time for some of robins DRL's then  :wink:
GTI MK5
Not the only GTI...........but the best! ; )
Offline Teutonic_Tamer
« Reply #12 on: 08 October 2008, 17:03 »
I think ordering a job lot from PB, and getting the freebies would work out cheaper than getting them all individually from the stealer.  I only mentioned it for those who had already upgraded some of their bulbs already.  And PowerBulbs only sell quality stuff from Philips or Osram, so will be as good, if not better than those from the stealer (which also happen to be from either Philips, Osram, or GE).
So the mains are released from the reflector with the connector still on?  I have come across that before, on Vauxhalls (whoops, that dreaded "V" word again!  :wink:  :grin:).  You just need to tease the bulb away with a flat-blade screwdriver.
Just think yourself lucky you didn't have to master these on the Xenons - they are real utter barstwards.  Not as bad as a Megane though!  :smug:
Yup, they are deceptively cool arnt they?  :cool:
Maybe because the dipped beams have the top half of the beam chopped off - so you are only getting half of the extra gain.?  :nerd:
Be carefull with fogs.  If you genuinely do use them in the fog, then upgrading the standard bulbs to these "ice white" or blue types of bulbs - and they will be considerably less effective.  You will get much more glare, and "bounce back" from the fog.  The best bulbs for fog lamps (front ones!  :tongue:) are "all seasons" type bulbs, which actually have a yellow type of coating, and don't look to dis-similar to the old skool "piss-filled" yellow frenchy headlamps.
If however, you just use them for posing, then go for it.
I feel like a homo
« Reply #13 on: 08 October 2008, 17:04 »
But they will be useless for genuine foggy conditions.  :wink:
I feel like a homo
Offline stealthwolf
« Reply #14 on: 08 October 2008, 17:09 »
I went for the philips X-treme stuff.
Nope, used my fingers and pushed the circular base from the connector.
Really? Then again, the dipped have the VW logo on them too.
Yeah I kinda figured that when I stood there admiring the view. It just looks odd but then again, I plan on using the foglights only when there's a fog! Not a fan of DRLs.
Offline indublin
  • "Hotel California" forum.... you can log off anyti
« Reply #15 on: 08 October 2008, 17:16 »
i got some free sides with mine, but they are blue??!!  :huh: will they shine blue or not? never bothered fitting them, but if they are white, il do it when i get home  :smiley:
Joe,
They shine a lovely bright white, I know I have one fitted (yes I could only get one of them little feckers changed).
Steel Grey 2006 GTi 3-Door - Monza II's - Tinted Rear Windows - Arm Rest
Offline gazman
« Reply #16 on: 09 October 2008, 18:34 »
just got my new bulbs from powerbulb.com and just found out why the give you the side lights w5w free.
 :undecided:
they are a pain in the arse to fit!!!!!
Offline AlanD
  • MK5 2.0T 16v
« Reply #17 on: 09 October 2008, 19:24 »
Yeah, I used a pair of pliers to get mine out.
Offline TagnuT
  • Edition 30
« Reply #18 on: 09 October 2008, 20:45 »
Used my fingers. The side lights are nice and white though.  :smiley:
I fitted the Phillips bulbs to the Mrs's car.
Bye Bye Edition 30
Offline AlanD
  • MK5 2.0T 16v
« Reply #19 on: 10 October 2008, 10:09 »
Used my fingers.
Your a real man then ;)
