Author Topic: Broken down...  (Read 3321 times)
Offline logeyboy
Re: Broken down...
« Reply #10 on: 07 October 2008, 12:22 »
does the bush pack come as part of the voltage regulator as they say they don't sell just the bushes?
Re: Broken down...
« Reply #11 on: 07 October 2008, 12:23 »
yeah I'm pretty sure it'll all be in 1 pice?  not actually done this job on a MK2 alternator only a MK3 which is a bit different!
Offline logeyboy
Re: Broken down...
« Reply #12 on: 07 October 2008, 19:47 »
Right then, bought a new alternator, just finished changing it and still not charging battery properly!
I'm gonna torch this thing soon.
Does anyone know what the bit in the red ring is on the back of my old alternator???
as my new one doesn't have this??
Offline richard s
Re: Broken down...
« Reply #13 on: 07 October 2008, 21:16 »
if you have enough power to get started get yourself down shalesmoor and go to chapmans auto electrics they recon starters and alternators and will test for you and tell you what is fecked
Offline danny_p
Re: Broken down...
« Reply #14 on: 07 October 2008, 21:22 »
that circled bit is a capacitor / condensor        it  stops your radio whineing
all the VW's have gone bar 1.
Offline bomp
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline logeyboy
Re: Broken down...
« Reply #16 on: 08 October 2008, 12:59 »
Thanks
My new aftermarket alternator doesn't have this part though??
I've fitted a new alternator & a new battery and I still get a faint flickering from the battery light to say it isn't charging?
Offline bomp
Re: Broken down...
« Reply #17 on: 08 October 2008, 15:58 »
the object opposite to what you've circled is the voltage regulator, and has brushes on it. http://www.germes-online.com/catalog/78/11/1283/116244/sell_voltage_regulator.html
It may be a dud battery, if your getting the light flickering, but as said earlier, clean all contact areas first.
I think Halfords do a free check on batteries, so it may be worth a look up to see if yours is functioning ok.
« Last Edit: 08 October 2008, 16:07 by bomp »
Offline logeyboy
Re: Broken down...
« Reply #18 on: 08 October 2008, 16:25 »
It's a brand new battery and  so is the alternator
I've tried 2 different batteries and it does exactly the same
Offline logeyboy
Re: Broken down...
« Reply #19 on: 10 October 2008, 11:24 »
It's fixed!
Wiring was completely shot, it's to be expected for a 19 year old car I guess.
Cost £45 to fix.  :sad:which is ok, but I bought a new battery and alternator needlessly...
