Golf mk3
hardmonkeys
Got a constant tapping noise :(
Topic: Got a constant tapping noise :( (Read 2112 times)
Burnsy
GTI forum regular
20 May 2004, 21:07 »
Just recently ive noticed a constant tapping noise coming from the engine ( top end i think )
It used to do it for bout 2 secs when starting up but its now staying on
Is it a know problem or is it serious ?
TiA
p.s Oli levels fine
Last Edit: 20 May 2004, 21:14 by Burnsy
golfvr6
Guest
Re:Got a constant tapping noise :(
20 May 2004, 23:45 »
Is it a mk3 vr6?
if so
probably worn tappets, try using flusher and changing the oil.
what is the mileage?
could also be worn chain tensioner or guide rail, but far more likely to be the tappets.
Burnsy
GTI forum regular
21 May 2004, 07:19 »
Yes its a Mk3 VR6 with 90 k on the clock
Is it best not to drive it or ok for a few days ?
Just started the car up to see if its still noisy but sounds normal
Ill see how it goes and take it in
Last Edit: 21 May 2004, 07:34 by Burnsy
golfvr6
Guest
21 May 2004, 15:31 »
Should be ok to drive.
Does the tapping noise still there when the engine is warm?
with chain wear , you will hear a rattling noise rather than a tapping noise.
Do the oil change with flusher.
Burnsy
GTI forum regular
21 May 2004, 21:04 »
Been on a good run today (motorway) and all seems ok the only thing it could of been is low on oil.
The thing is when i checked the oil 1 side of the dipstick reads low and when you look on the other side it looks as if theres plenty in.
Should i be checking the rough edge and not the smooth side of the dip stick.
* Burnsy sounds dumb
golfvr6
Guest
21 May 2004, 22:56 »
Pull the dipstick out, wipe it, put it back in , then take it out again, oil should be at the top of the 'rough' bit.
Do this check first thing in the morning, with the car on level ground.
Golf mk3
hardmonkeys
