Author Topic: Clutch pedal!  (Read 4234 times)
Offline ub7rm
Re: Clutch pedal!
« Reply #10 on: 07 October 2008, 20:03 »
As your brake pads wear does the brake pedal not 'fall' a little?
2020 BMW 128ti
2017 Golf GTD Estate
Offline Teutonic_Tamer
Re: Clutch pedal!
« Reply #11 on: 08 October 2008, 16:00 »
is it possible to adjust pedal/bite point for a quicker disengage/engage? (TT?)
Nope.  It is all hydraulic - meaning no adjustment.
I feel like a homo
Re: Clutch pedal!
« Reply #12 on: 08 October 2008, 16:05 »
I only rest my foot when doing a lot of town driving, but not so it burns the clutch out.
Still not good at all.  Driving instructor cars are generally "town driving", and they get through clutches like no-ones business.  Don't do it.  Modern hydraulic clutches are generally very sensative, and "light on the pedal", so any "resting" will cause the clutch to slip - even if you cant actually feel it.
I know its suposed to be the same height as the brake pedal but sits a tiny bit higher. Hope theres some adjustment in there with out taking too much up on the clearance?. But then if its a hydraulic clutch it can't be adjusted can it?
Have you had a look at the workshop manuals http://www.golfgtiforum.co.uk/index.php?topic=54324 in the maint section http://www.golfgtiforum.co.uk/index.php?board=59.0?  Only having two pedals, I personally haven't felt the need to look.  :tongue:  :grin:
I feel like a homo
Re: Clutch pedal!
« Reply #13 on: 08 October 2008, 16:08 »
Nope.  The pedal stays the same, but the level of brake fluid in the master cylinder resevoir "falls".  :tongue:  :nerd:  :wink:  :smiley:
I feel like a homo
neo66
Re: Clutch pedal!
« Reply #14 on: 08 October 2008, 17:48 »
Damm, I will just have to get use to it then! :cry:
Maybe go for the DSG next time!!!
Re: Clutch pedal!
« Reply #15 on: 08 October 2008, 18:04 »
You know it makes sense!  :tongue:  :wink:  :grin:
I feel like a homo
Offline SteveS
  • GTI ED30
Re: Clutch pedal!
« Reply #16 on: 08 October 2008, 21:10 »
thinking about it more today on the drive home due to reading this... grr its annoying... gotta lift your foot up really high to get it back on the pedal after having it on the footrest
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline 182_blue
Re: Clutch pedal!
« Reply #17 on: 08 October 2008, 21:14 »
I've never had any issues with the clutch position. Maybe it's a bad fitting or something?
me neither ?
neo66
Re: Clutch pedal!
« Reply #18 on: 08 October 2008, 21:32 »
Just been out driving in it tonight, I've just been having to put it into practice going from clutch to footrest! (were as I dont have to change gear as I am sure the Gti's have VVT!?)
