Author Topic: Superchips & JKM day out 6/10  (Read 38613 times)
Offline Teutonic_Tamer
Re: Superchips & JKM day out 6/10
« Reply #130 on: 10 October 2008, 15:27 »
if i was a carjacker i would just bang the driver on the head, most of them are pretty clued up on this sort of locking system so wouldnt go for the passenger side anyway, locking as you drive away is a must of course
Sound like an expert there!  :shocked:  :wink:
In all serious, this is one of the main reasons why I have Tracker on both, and have a Cat 5 one on the RS, so even if they had the keys, the tracker would still be activated immediately.  Sadly, though, the convenience module on Audis is different from Dubs, in that if you set it to autolock, then it will always auto unlock too!  So that is disabled on the RS.  :rolleyes:
I feel like a homo
Offline 182_blue
« Reply #131 on: 10 October 2008, 15:41 »
if i was that worried I would get a anti hijack kit, let them take it then call for back up and wait for the engine to cut out  :evil:
Offline Greenouse
« Reply #132 on: 10 October 2008, 19:32 »
Shaun, Stage two now loaded  :evil:
I agree it seems smoother (only a limited drive in rush hour) If I didn't know any better (I don't! ) I'd say the torque spread was wider...........
Offline 182_blue
« Reply #133 on: 10 October 2008, 19:35 »
yeh, did you get it free ?, its took a bit of getting used to as i think you can confuse sudden burts of power as powerfull (like old map did), this just seems to have constant steady boost all over the range, still more testing to go but im happy
Offline Greenouse
« Reply #134 on: 10 October 2008, 20:03 »
Yeh was free. I know what you mean, the first time I tried to boot it I thought it had reverted back to standard, but as you say it needs getting used to! Wheelspinning in third in the dry whilst doing about 40!!  :evil:
Offline RedRobin
« Reply #135 on: 10 October 2008, 20:36 »
....Is that the type of map you like?
Offline Greenouse
« Reply #136 on: 10 October 2008, 20:47 »
Being the only map I've ever had I'd have to say yes Robin. The TC picks it up ok but there's a definate power hike over the first map.
Offline 182_blue
« Reply #137 on: 10 October 2008, 20:51 »
haha, there is a thing called throttle control  :laugh:
Offline RedRobin
« Reply #138 on: 10 October 2008, 20:53 »
....It's just that I prefer to get the power down with a minimum of wheelspin, especially in the higher gears.
Offline Greenouse
« Reply #139 on: 10 October 2008, 20:55 »
As Shaun said, I can easily get over 36mpg so I know how to use the throttle as and when required  :wink:
