Author Topic: Whats going on the valver?  (Read 1688 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« on: 04 October 2008, 16:24 »
I have put a valver ABF engine in my MK3,  all the electrics are connected now (as far as i know)  and the engine turns over but it wont start,   this could be down to another issue so im not to worried about that.. but there is no ignition lights what so ever!   every thing else seems to work accept for the ignition lights, but i wonder if thats the reason for it not starting because sometimes when i start my 1.8 i turn the key and the engine turns over but will not start,  and the ignition lights all go out i have to let the key off and retry then the lights come on and it fires up.
Any ideas whats going on here?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline ToddyGTi
  • I Love GTi's
Re: Whats going on the valver?
« Reply #1 on: 05 October 2008, 10:19 »
Sounds like an immobiliser issue to me. I guessing the engine came from an 1995-onwards car?
The standard VW Immbiliser does this.
Part of the Booty Club
Offline Rmachines
« Reply #2 on: 05 October 2008, 13:34 »
Nope  :grin:  Its an L reg loom and had no stock imobiliser.  it did have an alarm/imob but i removed this and solderd it all back up,  so im a little bit lost.  :cry:
Offline danny_p
« Reply #3 on: 05 October 2008, 15:32 »
it's not Immob  as those engines start then cut out if they are still immobilised,  if not strartign at all  i would check for power  ate ecu , coil and injectors, if all of the above have power check for spark  if there is no spark check the enigne speed sensor  that lives behind the oil filter
all the VW's have gone bar 1.
Offline Rmachines
« Reply #4 on: 05 October 2008, 20:27 »
Knowing me i havnt even pluged the speed sensor in... i will check everything and report back.
Would this cause there to be no dash warning lights what so ever though?  indicator lights etc.. work as normal
cheers.
Offline danny_p
« Reply #5 on: 05 October 2008, 20:49 »
no dash lights what so ever ?    check the engine multiplug is fully home,  when the o ring gets a bit stiff  sometimes it can feel fully home when infact its just stuck on the o ring,  bit of oil on it can help.  defo worth checking the engine loom is getting power
Offline Rmachines
« Reply #6 on: 05 October 2008, 21:37 »
Will do that also. cheers!
