Author Topic: S3 Intercooler vs Forge Intercooler  (Read 49418 times)
Offline RedRobin
Re: S3 Intercooler vs Forge Intercooler
« Reply #40 on: 03 October 2008, 23:58 »
someone who knows what they are doing should not take 4hours to fit it.
....Really? How long do you think it should take?
Offline luca
« Reply #41 on: 04 October 2008, 00:02 »
RR i think a few people have done it themselves in 2 hours, cant remember who. I want mine fitted at awesome as its very near and the work they have done so far on the car has been very professional. They quoted me 4 hours but maybe thats a maximum as they may not have done an s3 one before. If it only takes them 2-3 then thats the labour you pay for.
Golf gti ed30, tornado red, itg panel filter, revo stg 2, team dynamics gloss black wheels, turbo back milltek, ecs dogbone mount, leon cupra brakes. s3 intercooler ordered.
Offline vRStu
« Reply #42 on: 04 October 2008, 08:42 »
Those sweet pipes on the VF unit overcome my major concern with the Forge setup, the pipes seem to be quite restrictive at the point where they spilt.
That aside I still prefer to maintain the OEM look so the S3 was the obvious choice for me. I also used the S3 pipework which is very good quality and not at all expensive.
Stu
Offline djhorace
  • Yee ha!
« Reply #43 on: 04 October 2008, 10:05 »
The Labour time to fit the S3 core and the above hoses is 4 hours, therefore £200+ Vat (£235 Inc Vat)
The Radiator needs to be drained down in order to fit the S3 core; therefore 2.5 litres of antifreeze will be required at £8.75+ vat (£10.28 inc Vat)
I have fitted 2 and I know it is not necessary for the radiator to be drained.
First one took 5 hours including finding bolts in the local stealer for the end of the side of the core. Second one took 2 hours.
Offline djhorace
  • Yee ha!
« Reply #44 on: 04 October 2008, 10:06 »
data logged a S3 today with TBE, intake & DV settings boost 9 timing 6 afr 9
car had just driven 100miles hard and should have been heat soaked......intake temps maxxed at 30.....says it all for a £300 intercooler!!!!
I know of 2 tuned Cupras with the same cooler and had exact same figures Carl :)
« Last Edit: 04 October 2008, 10:52 by djhorace »
Offline vRStu
« Reply #45 on: 04 October 2008, 10:08 »
I agree, if you are working inwards from the front then there shouldn't be a need to drain the coolant.  I changed mine from the engine side working forwards so the radiator did come out but the front slam panel didn't.
Stu
Offline revo carl
« Reply #46 on: 04 October 2008, 10:29 »
I will go s3 intercooler before i go stage 2 to be on the safe side.
Carl is stage 2 set at boost 9?
each and every car is different but that was running well within safe limits on boost 9 and was awsome! :)
stage2 still retains full variable switching so don't worry the car can still be setup to your liking :)
Offline djhorace
  • Yee ha!
« Reply #47 on: 04 October 2008, 10:47 »
Things tail off quicker with high boost though Carl, even with the fuel pump. Boost 7 seems to be the best compronise between performance and sustainability of power/torque. B8 T6 and F8 for fun :)
When will stage 2+ be available for those with the pump, intercooler, exhaust and proper intake?
« Last Edit: 04 October 2008, 10:50 by djhorace »
Offline Teutonic_Tamer
« Reply #48 on: 05 October 2008, 10:08 »
who is sean ??
I think they were referring to moi!  :wink:  :smiley:
maybe I can have his opinion :)
I'll read the rest of the thread before I jump in with my reply.
BTW, have you tried the serch funtion on the forum?  If you select "advanced search, then you can restrict answers to just the Mk5 section of the forum.  :wink:
I feel like a homo
« Reply #49 on: 05 October 2008, 10:09 »
I run the S3 one and love it, I've fitted and removed a forge one for someone and I wouldn't buy one I'm afraid.
Why not?  :huh:
I feel like a homo
