Author Topic: S3 Intercooler vs Forge Intercooler  (Read 49464 times)
Offline gazbutmk5gti
Re: S3 Intercooler vs Forge Intercooler
« Reply #10 on: 02 October 2008, 22:09 »
think that answers your question
         ED30 MLT :smiley:
Revo stg2+ & lots more
Offline RedRobin
« Reply #11 on: 02 October 2008, 22:10 »
Just looking at the purchase price of the S3 i/c and Forge i/c doesn't give you the true cost. So far I've had a quote of about £630 including vat for the S3 i/c.
Offline ED30_MLT
« Reply #12 on: 02 October 2008, 22:11 »
hi
I think the good choice will be the S3, I have seen APR insturction, they remove the complete front panel and headlamps to do it, I dont wish to mess with it.
Removing the bumper is no problem, Can you remove the intercooler without removing the front panel ???
Thanks
Golf Mk4 GTI Sold - Jabba Sport Stage 3 ran 340bhp
Got Evo 8 - sh!tty plastic car :( I missed my golf too much
Now Golf mk5 GTI ED 30 Black - Very Happy !!
Offline RedRobin
« Reply #13 on: 02 October 2008, 22:12 »
Whats the problem with taking off the front "panel"?
You need the bumper off to do both, and the only other thing you need to take off for the S3 core is the slam panel and dis-assemble the A/C from the cooler itself.
The good thing about the S3 core is that it has OEM appearance, and it wont restrict air to the A/C core or the OEM Cooler, and it does give 20% decrease in inlet temp over the OEM core.
Also, you could have an S3 core and a cat back exhaust for the price of a Forge unit.
I have an S3 core, and it upped boost upon spool and saw 20% drop in inlet temps overall.
....^That's the kind of info we need! :afro:
Offline djhorace
  • Yee ha!
« Reply #14 on: 02 October 2008, 22:13 »
hi
Thanks
Nope. You do need to remove the headlights to take the slam panel off though, and there is a crash beam behind it too actually, but it is all just nuts and bolts.
As memory serves from the 2 I have done
Remove bumper - disconnect fog light wiring and piping to headlight washers.
Remove Slam Panel and headlights
Remove crash beam
Remove screws from core assemblies and support A/C core
Disconnect core piping
Remove OEM core
And put it all back with S3 core.
Once you have done one, they are easy.
Be sure to order screws to fit the S3 core as the plastic screws used on the GTi core are plastic as the core ends on the GTi core is plastic, and the thread is different. Also be sure to order S3 pipes as the connections to the cores are different.
« Last Edit: 02 October 2008, 22:18 by djhorace »
Offline ED30_MLT
« Reply #15 on: 02 October 2008, 22:15 »
but the panel has to be removed right ??
I have seen APR instructions, they completly remove it, I am afriad of alignment issues when installing back
Offline Hurdy
« Reply #16 on: 02 October 2008, 23:01 »
I have the Forge Twintercooler and am very happy with the way it is working.
Yes the S3 unit looks OEM, but Forge back their product with gain figures over the stock system. See below.
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=0013&product=FMINTMK5
I have no doubt that the S3 gives gains too, so maybe do both :wink:
Seat Leon Cupra Black 290 DSG
Offline djhorace
  • Yee ha!
« Reply #17 on: 03 October 2008, 07:00 »
Being honest the lights were fiddly, but they can be adjusted fairly easily. Takes patience and a second pair of hands though.
Offline k4ith
« Reply #18 on: 03 October 2008, 19:25 »
You need to show about a bit more Robin.
S3 intercooler - £280 ish incl vat, fitted at same times as Dbilas £132.  nice
MKV Golf GTI Edition30, GIAC Pump&Race Map, AutoTech Fuel Pump, R32 Front Brakes, Dbilas Flo-master Intake, S3 Intercooler.ECS Dog Bone Insert.
MKII GTI 8v Tornado Red 88 - Das Projekt
Offline revo carl
« Reply #19 on: 03 October 2008, 20:44 »
data logged a S3 today with TBE, intake & DV settings boost 9 timing 6 afr 9
car had just driven 100miles hard and should have been heat soaked......intake temps maxxed at 30.....says it all for a £300 intercooler!!!!
