Author Topic: Dog bone inserts.  (Read 14353 times)
Offline Greenouse
Re: Dog bone inserts.
« Reply #40 on: 02 October 2008, 20:14 »
Anyone know where I can get a strengthened bolt as I already have the insert?  :wink:
I thank you  :smiley:
Offline bacillus
« Reply #41 on: 02 October 2008, 20:18 »
Just get a new bolt from your VW dealer. It will cost a little over a pound.
Without traction power is nothing!
Offline Greenouse
« Reply #42 on: 02 October 2008, 20:21 »
I confuse  :huh: If it's a dealer part whats wrong with the one already on the car?
Offline gazbutmk5gti
« Reply #43 on: 02 October 2008, 20:33 »
Think its a stretch bolt, so when you torque it down it stretches slightly, giving a sort of preload to it. If you then tighten it again the bolt has already been stretched once so the preload won't be the same. Some if not most cylinder head bolts are like this, also we use them on planes for important applications :smiley:
Revo stg2+ & lots more
Offline candy turbo
« Reply #44 on: 02 October 2008, 20:33 »
if its a stretch bolt once its been removed from its original tightness the bolt requires replacing !! :wink:
clubsport S no 215
« Reply #45 on: 02 October 2008, 20:40 »
could do with confirming if it is or not, but I'm pretty sure I read it somewhere :tongue:
Offline Greenouse
« Reply #46 on: 02 October 2008, 20:40 »
Thanks chaps  :wink: got ya now!  :grin:
Anyone know the 'official' name for it or will ''the stretch bolt from the dog mount insert'' do it?  :huh:
« Reply #47 on: 03 October 2008, 18:22 »
I fitted the ECS dogbone insert today, and looking at the bolt I don't think its a stretch bolt, looks like a standard big bolt :smiley:
There are markings on the head which I think relate to the strength of the bolt. The standard 1 was 8.8, the 1 that came with the ECS insert was 10. something. These aren't the size of the bolt as I measured them and the numbers didn't tie up.
Offline bacillus
« Reply #48 on: 03 October 2008, 19:06 »
It's a 21mm hex bolt with VW part number N105 580 01   :smiley:
Offline bacillus
« Reply #49 on: 03 October 2008, 19:09 »
The numbers refer to the physical hardness of the bolt. 10 is the hardest.   :smiley:
