Author Topic: Dog bone inserts.  (Read 14343 times)
Offline Bolle
Re: Dog bone inserts.
« Reply #10 on: 02 October 2008, 12:49 »
I would recommend fitting them.
I have the ECS one on my manual non Ed30 GTI with a remap.
The engine movement is reduced quite a bit, you haven't got that feeling of a large lump of metal bucking up and down in the car.
Shifts seem to be a bit smoother as well, and easier to make. Before with spirited driving I noticed I had to be quite precise when shifting. Most noticable for me the 2 - 3 upshift at high revs, just couldn't find 3 quickly and smoothy, not so anymore after the dogbone.
Pick-up of the car is also improved, you haven't got the feeling of the engine 'settlling itself in its mounts' before delivering power to the wheels.
On the negative side, I feel a bit more vibrations through the throttle pedal compared to before, and that is actually the only place I feel it continuously. I don't find that an big irritation or something to put me off, but that can be differen for each individual.
Furthermore you get a bit more vibrations if you balance the car on the clutch biting point with the engine at idle revs. A little revs cures that.
All in all I would recommend it, a great modification for little money.
Install was done (for free!  :smiley:) during a GTI meet at a local dealership. I would suggest you put the car on a bridge to do the install, it is a tight fit and you need some working room under the car to give it some leverage.
Offline bacillus
« Reply #11 on: 02 October 2008, 13:01 »
The key here is to lubricate the insert generously before insertion.   :smiley:
Without traction power is nothing!
Offline Egbutt Wash
« Reply #12 on: 02 October 2008, 13:11 »
£114 to have the dog bone exsert
Currently digging a bunker.
Offline bacillus
« Reply #13 on: 02 October 2008, 13:15 »
Where did you get that figure as the insert, depending on what make you get, will set you back between £23-30.
Offline 182_blue
« Reply #14 on: 02 October 2008, 13:44 »
Amazingly expensive for undoing and tightning one bolt
Offline joesgti
« Reply #15 on: 02 October 2008, 13:54 »
gonna order one from awesome now, where do they go?? any fitting help?? also what tools??  :smiley:
GTI MK5
Not the only GTI...........but the best! ; )
Offline 182_blue
« Reply #16 on: 02 October 2008, 14:00 »
Peskarik
« Reply #17 on: 02 October 2008, 14:02 »
On Neuspeed webpage there are instructions with pictures.
Offline 182_blue
« Reply #18 on: 02 October 2008, 14:06 »
http://www.neuspeed.com/data/installs/22.10.91.pdf   :wink:
Offline joesgti
« Reply #19 on: 02 October 2008, 14:14 »
thanks alot  :smiley:
looks p!ss easy, shame i dont have a torque wrench  :sad:
« Last Edit: 02 October 2008, 14:18 by joesgti »
GTI MK5
