Author Topic: Nippy then..  (Read 3591 times)
Offline Hurdy
Re: Nippy then..
« Reply #10 on: 29 September 2008, 22:57 »
Redline theoretical max in 6th gear is 187mph, given enough road, driver bottle, power and fuel, it could be done. When my speedo reads 150mph I'm doing 138 on the GPS. Given an error like that the guy doing 300kph would most likely be doing an actual 276kph, which is around 171.5mph.
Seat Leon Cupra Black 290 DSG
Peskarik
Re: Nippy then..
« Reply #11 on: 30 September 2008, 08:22 »
Then how do you explain the top-speed all the tuners give, that is set no higher than 260kph?
I think that is the maximum real world (GPS) speed you could reach in GTI, bouncing off the rev limiter.
For tuned S3's though, the tuners write 270-280kph.
WhiteGTI
Re: Nippy then..
« Reply #12 on: 30 September 2008, 09:08 »
The GTI surely has an overdrive ratio for 6th gear - therefore the top speed will be achieved in 5th...?
Offline Hurdy
Re: Nippy then..
« Reply #13 on: 30 September 2008, 18:33 »
Hi Peskarik,
Sorry I cannot explain tuners reasons for giving 260kph. All I can do is give you the stats I know myself. I'm working off the ACTUAL gear ratio's and redline figures as a theoretical max, rather than a tuners max :wink: Tuners will not post a theoretical max, but should (if they are reliable) give achieved max outputs.
Peskarik
Re: Nippy then..
« Reply #14 on: 30 September 2008, 19:09 »
Hi Peskarik,
Oettinger and ABT and B&B Automobiletechnik are reliable enough, no?
I just wonder, you know.
Offline WobGTI
Re: Nippy then..
« Reply #15 on: 30 September 2008, 19:53 »
that was the biggest waste of 56 seconds in my life!
Mk5 GTI | Full Leather | Winter Pack
http://www.symesmini.com
http://www.pinkmini.com
