Author Topic: Which headunit adaptor?  (Read 1337 times)
Offline Jimp
« on: 27 September 2008, 21:32 »
If I want to install a headunit using an adaptor for the wires instead of wiring it myself, would one of these be correct for the mk5? I don't have a multifucntion steering wheel or any other external stuff to control a headunit.
http://www.dvbcaraudio.co.uk/leads-leads-c-144_145_234.html
Last time I wired it myself but it was a pain and pretty slow and I don't feel like doing it again  :grin:.
« Last Edit: 27 September 2008, 21:34 by Jimp »
Not low enough mk5
Not on the road enough mk3
Offline SteveP
Re: Which headunit adaptor?
« Reply #1 on: 27 September 2008, 21:52 »
These will work but won't give switched live etc.
I would recommend the CAN BUS adapters as these are true plug and play, like this one http://caraudiosecurity.com/shop/product/products_id/8115.html
HTH  :smiley:
Offline AlanD
  • MK5 2.0T 16v
« Reply #2 on: 28 September 2008, 12:01 »
If you dont want to do any wireing yourself then you need the CAN BUS as Steve pointed out. If not pop into any Car Audio shop and they will have a simple adaptor for about £10.
Steve, thats a mighty impressive price you have found for the that adaptor.
Offline Jimp
« Reply #3 on: 28 September 2008, 21:37 »
HTH  :smiley:
Thanks for the link Steve  :smiley:. Just a case of plugging the VW connector to one side and the headunit connector to the other?
Not low enough mk5
Offline SteveP
« Reply #4 on: 28 September 2008, 21:48 »
HTH  :smiley:
Yep this will provide the ISO connectors your aftermarket headunit will come fitted with  :smiley:, the only thing to check is if this one includes the aerial adapter as well as the VW OEM headunits also use a different type of of aerial connector, if not then you will also need one of these: -
http://caraudiosecurity.com/shop/product/products_id/8126.html
