Author Topic: URGENT - water light issue  (Read 2087 times)
Offline cняis
Re: URGENT - water light issue
« Reply #10 on: 26 September 2008, 00:00 »
cheers both,
 job for tomorrow then ,
then i can use one  fromthe spare donk,
then finally bleed the system properly,
check the stat and matrix for leaks,
rebuild the interior,
fit the pas pump back on,
and then get sponsorship from savlon, i am cut to shreds   :grin:
you have finally passed the initiation! good old heater matrix replacement!   :grin:
Offline Goops
  • mk2 gti 16v
« Reply #11 on: 26 September 2008, 00:21 »
conker had same problem,
changed coolant tank and tried all configurations of the senders and readings didnt change..light still flashing!
Funny thing is, it suddenly stopped flashing in the good summer weeks and started flashing again recently!
Ive left it to the clocks..... :lipsrsealed:
Good luck  :smiley:
Offline Conker
« Reply #12 on: 26 September 2008, 07:37 »
Mine was faulty expansion tank wiring. Bought one from ECP and all sorted.
Offline JC
  • Back in the North.
« Reply #13 on: 26 September 2008, 07:39 »
right then, up at 6am  :shocked: and started afresh.
changed all 3 sensor wires rounds. STILL the same  :cry: engine running ( neighbours will no doubt be round complaining again )  or just ignition on
went out of the garage and chose one of the 2 corsas to kick - daughters was nearest - kicked satis  :smiley:
went back in and put everything back to how it was.
  started back at the begining. water level good ( still trying to bleed and leak check )
Bridged the expansion tank wire again - PROBLEM VANISHED  :undecided: :angry: so I am hoping that I have cured summat by doing nothing or just moved the fault in the short term. Annoying thing is, the tank is only 5 months old  :cry:
so it looks like its a trip out this avo for a new expansion tank , redo the bleed and leak check, then complete rebuilding it all so i can take it off the road in 5 weeks .
CHRIS - to be honest, the cuts arent really from doing the matrix, just the hissy fits or the thing not working and me ripping my hands out of tight spots  :laugh: :embarassed:
Offline JC
« Reply #14 on: 26 September 2008, 07:39 »
see above  :laugh: :lipsrsealed:
Offline Conker
« Reply #15 on: 26 September 2008, 07:43 »
Great news - nice and easy fix.
Offline JC
« Reply #16 on: 26 September 2008, 07:46 »
Not 100% sure its that Dave. but the only way to tell is to change it, then get the car run up to temp, bled etc.
Then i will see. spooky how the Stat, the Matrix and the expansion tank all go pete tong together, unless the stat failing took out the tank and the matrix  :undecided: :cry:
« Reply #17 on: 26 September 2008, 08:02 »
could be dodgy wiring to the header tank, have a good look at it!
Offline JC
« Reply #18 on: 26 September 2008, 09:06 »
but but jumping the connector ( which is clean etc )  it cures the fault - wires look ok and i wiggled them and the fault stayed gone.
could the fact the stat was stuck closed cause the float to go tits up ?????
« Reply #19 on: 26 September 2008, 09:12 »
yeah, but you said you tried this before and it didnt fix it, hence slightly dodgy wiring ;)
