Author Topic: help with door handle?  (Read 2879 times)
Offline _Adam_
Re: help with door handle?
« Reply #10 on: 24 September 2008, 18:31 »
well i got the door card off and only snapped 2 clips on the actual inside handle, no problem.
once i got it off i realised there's no way you cn possible get to the mechanism from inside the car, the back of the door behind the card is one big metal sheet with no holes to get through.
does anyone know how to get the external handle off? halfrauds dont seem to sell a mk5 haines
Offline Rhyso
« Reply #11 on: 24 September 2008, 18:43 »
have a look at the edge of the door - should be some screws??
might come off the same way a MKIV handle does - think its one torx screw on the edge of the door  :undecided:
Offline _Adam_
« Reply #12 on: 24 September 2008, 22:34 »
there's torques arrowed but i started to undo them and realised that even if i remove the lock piece, there's still nothing i can do with the handle and i might not be able to get it back inplace afterwards. after tampering it seems to be working fine now anyway... see how it goes
