Author Topic: ABF Driveshafts  (Read 1992 times)
Offline matt r
ABF Driveshafts
« on: 22 September 2008, 23:05 »
Exactly which mk3 driveshafts can be used for the ABF 16v?
For instance 8v.
Will any mk3 shaft fit providing it has abs?
Matt
Offline MowatGTI
Re: ABF Driveshafts
« Reply #1 on: 22 September 2008, 23:12 »
Might be worth calling a dealers in the morning.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: ABF Driveshafts
« Reply #2 on: 22 September 2008, 23:51 »
the 8v shafts fit the 16v,  i have just fitted an 8v shaft with a knackerd CV joint so i fitted a 16v joint to the 8v shaft... all went together fine so i guess it must be identical
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
