Author Topic: Turbo's gone.  (Read 4506 times)
Offline mrlapou
  • Mean GTi
Re: Turbo's gone.
« Reply #20 on: 19 September 2008, 18:58 »
Could simply be the acuator arm or vanos vains sticking. Quite common if innerads are all carbon incrusted.
Offline Saint Steve
Re: Turbo's gone.
« Reply #21 on: 19 September 2008, 19:11 »
I very much doubt its a mechanical failure with the turbo. If the turbo has thrown a blade, it wouldnt work for 10 mins and then die.If somethings come off it wont work period.
Sounds more like some kinda sensor failure causing the car to go into limp home mode.
Im sure it wont be as bad as "MR No it All" AA spare part in yellow Uniform says.
Do report for us after your visit to the dealer.  :smiley:
Offline Teutonic_Tamer
Re: Turbo's gone.
« Reply #22 on: 19 September 2008, 19:26 »
Vanos is BMWs name for its variable inlet cam timing.  But I get your drift.  :wink:
BTW, I am liking your LEDs in the headlamps - got any more info?  :smiley:
I feel like a homo
Re: Turbo's gone.
« Reply #23 on: 19 September 2008, 19:35 »
Not really.  It is extremely rare for a turbo to "throw a blade" - if they ever do, then the turbo would suffer catastrophic failure, and the damage would be very visible.
But it is fairly common for the VNT turbos to seize up their VNT mechanisms.  This wouldn't and/or shouldn't be apparant or noticeable when starting from cold, as you should only use the engine gently whilst cold.  Only after the engine has reached normal operating temperature, will you start to boot it and give it some beans - and this is when the VNT will be at its most "active".  The VNT mechanism works along the same lines as any other actuator, in that the ECU instructs it to "work", and after the item has "worked", a signal is sent back to the ECU to confirm that it is working OK.  If the ECU doesnt get the "I'm working fine command", that is when the ECU can then change to "limp home mode".  :nerd:
Yup, that too.
Agreed.  I never trust those types.  :rolleyes:
Yup, we need to know!  :tongue:
I feel like a homo
Offline stokeballoon
Re: Turbo's gone.
« Reply #24 on: 19 September 2008, 19:38 »
Offline Edition30
Re: Turbo's gone.
« Reply #25 on: 19 September 2008, 20:14 »
Anything the AA/RAC say I would take with a pinch of salt, my dads Passat TDI broke down once and that went pretty much into limp mode...the turbo wasnt coming in at all and the guy said prepare yourself for a big bill as your intercooler is foooked. Turned out it was a split pipe.
sorry but my vaux looks far better than the mk5 gti, thats why i bought it  :wink: faster too  :grin:  :tongue:
July/08 Pearl Black Golf GTI Edition 30
Offline Pabs32
  • Hello
Re: Turbo's gone.
« Reply #26 on: 19 September 2008, 20:57 »
I had a split pipe on my 04 reg 150bhp PD GTI, which gave a huge performance hit
Stick your head under and have a poke would be my advice
CW Ed30 3dr DSG, Xen, Highline, Satnav, IPod, Park sensor, Sunroof
