Author Topic: Digi-lag??  (Read 3804 times)
Re: Digi-lag??
« Reply #10 on: 22 September 2008, 10:36 »
the afm mod is also usefull for older afms that have gone out of spec a bit, or have worn contacts on the pcb.  its a bit of a black art though more often than not you cause more problems than you fix!  Always leave this till you have tried everything else :)
also worth noting the afm off a MK3 2.0 8v will also fit a MK2, has the same bosch part number :)
Offline MarkS
Re: Digi-lag??
« Reply #11 on: 22 September 2008, 12:09 »
Would a mk3 afm offer any advantage over a later mk2 afm? :)
Just realised- when you say same part number, does that just mean its the same part?
« Last Edit: 22 September 2008, 12:18 by MarkS »
Offline kittie
Re: Digi-lag??
« Reply #12 on: 22 September 2008, 13:18 »
Follow the infamous rubjonnys digi timing guide! It worked well for my car.
Re: Digi-lag??
« Reply #13 on: 22 September 2008, 13:27 »
mk3 part is the same so no advantage, I managed to pick up a newun off ebay for £50  :cool:
the VAG part number differs for some reason, but I compared the bosch number on both the new one and the one I took off and it was the same. No idea why the VAG numbers differ, perhaps they have a different 'default' setting on the screw or summat.
Offline Mr Blue
Re: Digi-lag??
« Reply #14 on: 22 September 2008, 20:27 »
just an update on mine.
Was the airflow meter that caused this lag. :angry:
Offline richard s
Re: Digi-lag??
« Reply #15 on: 22 September 2008, 20:36 »
mine seems fine on set off but in second if i let off then re accelerate there is a slight delay is this digilag
