The Mk5 Golf uses existing fittings, ie, remove a couple of torx screws, offer up the mud flap, and then reuse same fittings. They also need a couple of holes punching, just with a bradawl though, the fronts are through the plastic wheel arch liner, and the rears are through the carpet-type liner. If you can change a wheel, then you can fit the flaps. They even come with very good, detailed fitting instructions, with pictures.
HTH
