Author Topic: Radiator help, 16v  (Read 1178 times)
Offline Spam
Radiator help, 16v
« on: 09 September 2008, 15:50 »
Hi Ya,
I have a hole in me radiator...:0(
Can anyone tell me, other than the radiator and the 2 or 3 hoses, is there anything else i should change while im doing this? i.e. thermostat ect
Let me know if anyone has done this.
Thanks
Spam
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Radiator help, 16v
« Reply #1 on: 09 September 2008, 15:53 »
No not really the thermostats a whole other job in its self so i wouldnt worry about that if its working.  its common for the bottom right of the rad to busts on these so just change that radiator its self.  you usualy have to swap over the fan switch, could fit a new one of those to be safe?  other than that its just the radiator you need.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline madhouse
« Reply #2 on: 09 September 2008, 15:57 »
Rmachines has summed it up really, other than a good mix of coolant. Just the rad, switch, and maybe a few hoses to be safe  :smiley:
A nice Sunday afternoon job  :wink:
Offline Spam
« Reply #3 on: 09 September 2008, 16:15 »
Thanks guys,
so do i have to remove the bumper and cross member?
Spam
Offline madhouse
« Reply #4 on: 09 September 2008, 16:21 »
Wouldn't have thought so. It just unbolts and lifts straight up and out doesn't it? Should take no more than an hour tops.
Drain system [slacken bottom hose]
unbolt rad and hoses
clean up the area [optional  :grin:]
replace rad with new sensor switch
hoses on
refill with coolant
Run the engine with heater turned to HOT [so that water runs around the heater matrix]
check for airlocks
DONE  :smiley:
*chances are jubilee clips will be seized, bolts will be rusty, and you will slip with a spanner and slash a knuckle or three - so maybe 3 hours  :grin:
Offline Rmachines
« Reply #5 on: 09 September 2008, 16:22 »
you do have to remove the bumper on the MK3.  The cross memeber can just be slackened but it comes off easily enough so doesnt matter really.   bumper is just a series of 10mm bolts and then pop off the plastic retainer to connect it to the wheel arch plastic.
Offline madhouse
« Reply #6 on: 09 September 2008, 16:26 »
Really? Ooops soz Spam, I am new to Mk3 Dubs so I've learnt something new there too  :embarassed: Bit OTT just for a rad but hey ho  :wink:
Maybe do a rad replacement thread Spam with pictures??  :huh:
There's this bit in the help area about getting the bumper off [front is about half way down]  :wink:
« Last Edit: 09 September 2008, 16:46 by madhouse »
Offline Spam
« Reply #7 on: 09 September 2008, 17:17 »
Thanks for the help guys.
I will take some pics while i do the swap, then i will post them just in case it's of use to anyone.
Spam
