Author Topic: Improving gear changes  (Read 8111 times)
Offline RedRobin
Re: Improving gear changes
« Reply #20 on: 09 September 2008, 18:16 »
....Each To Their Own (ETTO), Pesk :afro:
Offline Saint Steve
« Reply #21 on: 09 September 2008, 18:49 »
robin you are soooo naughty posting that link!! but its soooo true that video. i heard from the somewhere, that the speed in dsg gearchanges will be equivelent to having approx 30 xtra horsepower approx in 0-60 run (if its straight line speed comparison you after)
I guess it all to do with your motion and technique, start off slow, dont push her too hard or she gets put off, ease her gently, untill shes opened up and warmed up nicely.Getting a good feel when it the wet is always best, and try not to do it whilst trying new manouvers. If it pops out, can hirt if you catch it wrong.
HTH your style, hope you get as slick as the rest of us  :wink:
Phil  :smiley:
Offline stealthwolf
« Reply #22 on: 09 September 2008, 23:07 »
3 seconds to change a gear - are you narcoleptic or something? :shocked: :laugh:
Lol it's not actually three seconds but it bloody well feels like it, especially compared to DSG. It's more like
 - clutch to floor
 - change gear (probably takes bout as long as any of you guys)
 - clutch to biting point quickly, and a little more slowly to full raise
Are you only interested in going up through the box or down as well?
Both.
Coming back down through the box, I use rev matching to smooth out the gear change again. This can be achieved by blipping the throttle to match the higher revs as the gear is engaged, or sustaining the revs.
What is blipping and how do I do it? I've tried heel-toeing before without success. Managed to kinda figure it out in the fiesta but wasn't very good at it.
1st to 2nd is a different story, and I very rarely go through it quickly without a bit of a jolt when releasing the clutch.
That happens to me and it looks to others like I can't control the car.
If y'all recommend advanced driving tuition, who'd be the best people to go to?
Offline RedRobin
« Reply #23 on: 09 September 2008, 23:23 »
....Advanced driving tuition tends to be more about roadcraft than such things as gearshift techniques. It usually assumes you have already mastered such things.
A course such as CarLimits may be of some use - You basically explore the absolute limits of your own car under tuition and on North Weald airfield where you can't hit anything. Be prepared for a full day of very severe tyre wear and 11 mpg!!
Offline Cass
« Reply #24 on: 10 September 2008, 08:10 »
Advanced Driving:
I - Information (road conditions/hazard/signs/traffic etc)
P - Position (of your car on the road)
S - Speed (correct speed relative to the hazard)
G - Gear (correct gear for the manoeuver)
A - Acceleration (through the hazard)
Cass
Now: VW Touareg Altitude V6 TDI 3.0 240 bhp, Diamond Pearlescent Black
Previous: MY2007 GTI, 3 door, manual, pearlescent black and lots of toys - gone to a good home : )
Offline ChrisBuer
« Reply #25 on: 10 September 2008, 09:52 »
I’d have to disagree with that comment Red to a certain degree. IAM and RoADA do focus on Roadcraft and the IPSGA system (Information, Position, Speed, Gear and Acceleration). However, you do focus on elements such as smooth gear changing as I’d say about 99% of people who have passed the DSA test cannot gear change properly. This is the sort of gear changing that is still quick but that you cannot feel in the car. My old instructor used to say “imagine there is a pot of paint sitting in the passenger footwell and you don’t want to spill it”. The real art is actually making more progress than you did before, but without “spilling the paint” by smooth gear changes.
There is a lot to learn from advanced driving and I think there is a stigma sometimes attached to it. Some people seem to think that it’s a bunch of flat capped old men moaning about speed limits. In my experience, the likes of IAM can be a little bit like this, however once you start doing courses such as the RoADA test and move up to look at entry into the HPC (High Performance Club), you realise that in fact, it’s full of petrol heads!
To give you an idea, I went out with one of the former gatekeepers of the HPC (the guys that decide if you can get into the club). This guy had a standard Golf TDI and we followed him onto the track at Bruntingthorpe to go over to our area where we were doing our activities. I was in a Caterham R300 (300 bhp per tonne) and the other guy was in an M3 (previous version). I kid you not, we could not keep up with this guy in the Golf because on the corners, he was just leaving us for dead. It was a little bit damp but neither of us could keep up. Why? Because he was applying all of the techniques (albeit at a high level) that you learn.
The sort of techniques that you pick up in the higher level RoADA and entry level HPC training are things such as…
Rev matching - You can use techniques such as Heel and Toe (see here http://www.youtube.com/watch?v=JliPGde8jMM) which basically allows you to brake and match the revs at the same time. This stops the rear end of the car (diff) locking up. You may have heard that the drifters use diff locking to get the car into a slide and the back end out to drift it around the corner. This happens when you lift off the clutch sharply which snaps when the gear is re-engaged. Therefore heel and toe stops this happening.
You can also “blip” the throttle to rev match and that can be achieved by doing the following. You’re in third gear, approaching a bend, on the brakes to reduce the speed, off the brakes, engage the clutch, select second gear, before you lift the clutch to the biting point you blip the throttle to bring the revs up to match the revs needed when the clutch is engaged. For example, if you’re doing 3000rpm in third gear at 50mph and select second gear, you might then be at 5000rpm. So what you’d do is blip the throttle to 5000rpm and then lift the clutch to engage second gear. This basically stops the jolting in the car and makes for a smooth gear change. If you listen to the DSG box, it blips on the down-change :)
There are a number of other techniques taught in advanced driving and I’ll not go into all of them, otherwise I’ll by typing all day but a few are:
1. Balancing the car on the throttle. There is a lot of work you can do on the weight shift of a car. Again, going into a corner, a lot of people will brake and make their gear change going in, stay off the power until the apex and then stamp the throttle down again. The faster way is to brake, heel and toe gear change and then come back on the throttle (very lightly though) to balance the car through the bend.
This light throttle balances the weight of the car evenly and sets it up better (especially at higher speeds). If you go in braking and changing gear, all of the weight is on the front of the car which means the rear of the car can be light. If this happens when you turn in, you can put the car into a spin. At low speeds, you’ll not notice it, but once you get to higher speeds, it makes all the difference. Basically the same happens when you lift off on a bend. The weight shifts to the front and you get “lift-off oversteer”. Great fun on the track, but not something you want to be doing on the way home from work in rush hour  :grin:
People also steer too much. You can get away with a lot less steering than you think and actually drive the car on the throttle. Again it's all about balance and application and not something I can really explain very well by typing it.
2. Ever heard the phrase “you must never brake on a bend”? Yep me too until one of the advanced instructors said to me “yeah unless you’re using trail braking”. What’s this I hear you ask? Well I’ll not go into it (google it) but it basically allows you to enter and exit a corner on full throttle.
Basically there is tons to learn and I took the decision a while ago that it doesn’t matter how fast my car is, it’s only as good as the driver in it. It’s humbling when you see a guy in a TDI MKIV Golf leaving a guy in his 345bhp M3 in his dust just because he’s an amazing driver!!
I’m no expert, but from what I’ve seen, there is a lot to be gained from learning this stuff. Oh and many benefits as well. Only a couple of weeks ago the HPC invited me and a number of others to go to Millbrook with them. It was un-restricted access to drive around the facility. I went on the High Speed Bowl, wet skid pan, outer handling circuit and the famous Alpine Route.
It was a fantastic day but there were two highlights. The first was getting taken out as a passenger in a 350k Porsche Carrera GT! But the best bit was watching one of the top HPC drivers in my car, chasing the Carrera GT on its hot lap around the Alpine Circuit and the Carrera could not shake us of his tail!! Yeah my car is quick but it’s not THAT quick! There’s no way I could have kept up, but it just goes to show you what a good driver can do!
Anyway, I’ll stop babbling now :)
« Last Edit: 10 September 2008, 10:22 by ChrisBuer »
Supercharge me!
Offline RedRobin
« Reply #26 on: 10 September 2008, 10:13 »
....Great post, Chris - I'm glad I made my comment if only because it prompted yours so very fully :afro:
I think I know who that guy in the Golf TDI is - I've heard of that happening before.
I wasn't given much input on my actual gearshifts on my Drivetrain course, possibly because of having DSG, but I was encouraged to use the gears to optimum effect much more - To be in the appropriate gear at all times.
Offline ChrisBuer
« Reply #27 on: 10 September 2008, 10:36 »
Thanks Red  :afro:
I try not to put many posts up on advanced level driving because I don't want to be seen to be preaching, but there is just so much out there to learn.
I always hold back when someone posts up a thread like "how can I make my car faster" and everyone comes back about lowering the car, remapping it etc. Sure, these sorts of mods do make a car more fun, but you can't transfer it car to car. Hell, I've put on a sports exhaust, sports cat and performance airbox on my car, but only because I like the sound and improved throttle response, so I'm not saying people shouldn't mod. I mean I only have to look at your car to think how good it looks now compared to the standard GTI!
However, with improving your driving, you really can exploit the most out of the car. The guy in the TDI is called Don Palmer and he is the limit handling god! He took my car out at Millbrook and we were lapping 450bhp Porsche Turbos! LAPPING THEM!! I went around and I could keep up with them, but I wasn't getting anywhere near lapping them. He was sideways on most corners and trail braking into nearly every single one. At times I thought "there is no possible way on this earth that we're going to make that corner...I would have braked about 20 seconds ago" and low and behold, we go through the corner and I'm sitting there thinking "...how....how is that possible?!?!". I mean I know what he's doing but I can't replicate it haha! I've been out with this guy sliding around a corner in a Caterham at 120mph and this was quicker than I was managing on the straights!
It just puts it all into perspective really. As much as I love cars, I love my driving just as much and the more I learn to improve it, the more fun I get out of my car!
Supercharge me!
Offline Cass
« Reply #28 on: 10 September 2008, 10:51 »
Agree - cracking post Chris :smug:
Cass
Offline ChrisBuer
« Reply #29 on: 10 September 2008, 11:16 »
Thanks Cass :afro: From your posts I can see that you've had training yourself. What sort of things have you done so far?
Red - If it's limit handling you're interested in, then I agree, the CarLimits days are fantastic value for money. Their activity days are only £38 for the day and I know through the Lotus forums, you can get the same day for £20!
However, what I'd recommend to anyone interested in this is go out and get some training first (a limit handling day with Don Palmer is a good place to start). Then when you go to the track, you can work on and apply the techniques learnt.
Whenever someone from the Lotus forums has a spin on the road and posts about it, everyone always posts the same thing - Activity day at CarLimits. Whereas this is undoubtedly the right thing to do (i.e. go to a track and mess about with the car safely), I can't help but think that they'll go there only to do the same things badly but at higher speeds. There is no learning in that. It's best to get some training and go and practice it, otherwise when you do finally get some training, it's harder to undo the years of doing something wrong.
I think the hardest part for most people is that they worry about someone criticising their driving. It's very much a macho thing and when I'm out with mates, I'll never say to them "oh I wouldn't have lifted off there" or "I wouldn't have used that gear". It's not my place to say so. However, I guarantee all it would take is one hot lap around a track with someone like Don for them to realise that actually, as good as they think they are, they're not even on the scale of what can be achieved with a bit of work.
Supercharge me!
