Author Topic: weird clunky reversing noise!  (Read 1571 times)
Offline Drewcole
  • DaZeD aNd CoNfUsEd......
« on: 05 September 2008, 09:26 »
On reversing my beast makes a kinda of rotating clunky noise... any thoughts?
Offline Blackie_No1
  • GTi baby!! woop woop!!
Re: weird clunky reversing noise!
« Reply #1 on: 05 September 2008, 09:39 »
Have you the sterring pulled one way or the other when this is happening?  If so it could be a CV joint.
'97 8v GTi, Piper S/Steel Zorst, K&N panel Filter, Jamex 40/35 kit & Gas shocks
Offline Drewcole
« Reply #2 on: 05 September 2008, 10:19 »
Not that I have really noticed to be honest, I have been trying not to reverse much!
Its only when its in gear though. If I reverse and take it out of gear and roll then it doesn't make the noise, so makes me think its the box.... which i'm hoping it isn't.
Offline Blackie_No1
« Reply #3 on: 05 September 2008, 11:19 »
Definitely a "rotating" noise?  sometimes the anti roll bar will clunk in reverse if the bushes are shot.
Offline Drewcole
« Reply #4 on: 05 September 2008, 11:21 »
Ummm.. I think so yeah.
I'll have a look at that though, the front camber is slightly off so may mean the bushes need doing?
Thanks, gives me a job for the weekend.
Offline snifferdog
« Reply #5 on: 05 September 2008, 11:34 »
have you checked the engine mounts? mine used to do it until i renewed the mounts!
Offline Drewcole
« Reply #6 on: 05 September 2008, 11:40 »
Front one has a very slight amount of play in it, was going to change it anyway so may do that first then. I was planning on just jacking the engine and changing it on the drive....
Offline irmscher
  • Mobile Engine Tuning www.premiertuning.com
« Reply #7 on: 05 September 2008, 11:56 »
Actually i'm surprised nobody has mentioned this yet but it sounds like a chipped tooth on your reverse gear, very very common MK3 GTi's and we had to have a new gearbox on my bro's MK3 because of this very problem.
Mobile Engine Chiptuning & Remapping Specialists
Cars tuned from £199 at base
info@premiertuning.com or Facebook
Offline Drewcole
« Reply #8 on: 05 September 2008, 12:03 »
I was hoping it wasn't that!!!
I may get a quote for a new gear box though, is there a code that I should ask for?
Offline Splash
« Reply #9 on: 07 September 2008, 10:13 »
I had this with mine. Went to gearbox specialist and he said the flywheel had a high spot and that when the clutch was replaced (prior to my ownership) that it should have been skimmed. He said drop it in 2nd before reverse and it will stop flywheel spinning and the crunch. Works for me.
