Author Topic: INTERIOR LIGHT NOT WORKING WHEN OPENING DRIVERS DOOR  (Read 2158 times)
Offline SHARPYSGOLF
« on: 05 September 2008, 06:41 »
HI, BOUGHT MY GOLF A FEW MONTHS AGO AND WITH IT BECOMING DARK NIGHTS HAVE JUST REALISED THE INTERIOR LIGHT DOES NOT COME ON WHEN OPENING THE DRIVERS DOOR? ANY OTHER DOOR THAT I OPEN IT WILL THEN COME ON WHICH SOUNDS ABIT WEIRD! THE INSIDE DOOR CARD LIGHTS DO THE EXACT SAME WHICH TO MY KNOWLEDGE ARE ALL APRT OF THE SAME WIRING I GUESS. HAS ANYONE GOT AN ANSWER AS I'M STUCK AS TO WHERE TO START LOOKING? CHEERS
SHARPY
Offline richw911
Re: INTERIOR LIGHT NOT WORKING WHEN OPENING DRIVERS DOOR
« Reply #1 on: 05 September 2008, 07:41 »
Faulty door module:
http://www.golfgtiforum.co.uk/index.php?topic=86403.0
Offline SHARPYSGOLF
« Reply #2 on: 05 September 2008, 09:26 »
what does that mean? and how much approx to get repaired?????
SHARPY
Offline Rhyso
« Reply #3 on: 05 September 2008, 09:39 »
re-read the topic mate - the prices are in that link..........
Offline GAZ 5570
« Reply #4 on: 06 September 2008, 12:58 »
These can usually be repaired if you can work a soldering iron - there is a good how-to on vwvortex :wink:
save yourself a few bob!
Offline richw911
« Reply #5 on: 06 September 2008, 13:53 »
True lot of hassle tho IMO
Offline GIJo
« Reply #6 on: 07 September 2008, 21:10 »
I just spent all day mending mine. My car didn't recognise the door being opened so puddle light and courtesy light didn't work and it didn't beep if I left my lights on. I didn't have the common fault of cracked soldering - the microswitch in the mechanical portion of the door module was knackered. I went to Maplin at bought miniture microswitch (part no N95AQ) and followed http://forums.tdiclub.com/show...&vc=1 and it all worked out well. Some of it was a bit trial and error when reassembling the door and I got the NO and NC round the wrong way on the switch on my first attempt but I had lots of fun with a multimeter and saved a bomb! Good luck!
