Author Topic: steering/suspension creaking issue.... Fixed!!  (Read 2801 times)
Offline RobC
Re: steering/suspension creaking issue.... Fixed!!
« Reply #10 on: 13 May 2009, 20:42 »
have you still got the pic mate? what exactly did you fit, my golf seems to have the same symptons now just trying to find out what it could be
Offline Adam
« Reply #11 on: 13 May 2009, 20:55 »
Have you just fitted coilovers/springs?
Down Hill From Here.
Offline RobC
« Reply #12 on: 13 May 2009, 21:01 »
nope, its lowered on springs but that not a recent thing, was the hub/bearing problem coilover related then?
Offline Adam
« Reply #13 on: 13 May 2009, 21:04 »
Mine creaked like BBs but it ws because I had not fitted the bearing the correct way.
Offline boneybradley
  • Back in a Mk3...
« Reply #14 on: 13 May 2009, 21:10 »
wasnt related on mine!...I changed wheel bearings not long before the creak and everything was tight still, but when I removed the hub you could see the bearing had burned the seal. it passed an mot with the issue as everything was fine (at a main dealer too! but there was no odd movemenet on the bearing anywhere!). if you have similar issues I would remove the hub and check the bearing
