Author Topic: Door Mirrors and washing your car ANNOYING!!  (Read 4869 times)
Offline Greenouse
Re: Door Mirrors and washing your car ANNOYING!!
« Reply #20 on: 05 September 2008, 13:14 »
My Fix to this problem is to wash and rinse car.Quick spin round the block.Then towel off.... Sorted.
Exactly what I do.  :wink:
Me too, but the reason I do it is to get rid of the rust from the disc's  :angry: This really does my head in!!! (or am I the only one who likes my wheels to be clean on the inside?  :embarassed:)
Offline Top Cat
« Reply #21 on: 05 September 2008, 13:18 »
Me too i hate rusty disc's.  :angry:
Offline RedRobin
« Reply #22 on: 05 September 2008, 14:34 »
....How do you get rusty discs? Do you mean the hubs?
Offline bobotheclown
« Reply #23 on: 05 September 2008, 14:39 »
whenever my brake discs come into contact with a little bit of water they instantly rust up. A spin around the block gets rid of the rust but it is strange.
Offline SteveP
« Reply #24 on: 05 September 2008, 15:01 »
Ditto, the disc face rusts up very quickly after contact with lots of water.
Plus the normal and ever growing amount of rust of the hubs.  :angry:
Offline Teutonic_Tamer
« Reply #25 on: 05 September 2008, 19:25 »
Rusty disc faces - probably because you lot never let a jet wash get near your car.  :rolleyes:  The calipers/discs/pads can collect brake dust, which has microscopic metallic particles in it - hence a large metallic surface area.  This large metallic surface area then "faciltiates" the rapid rust build up - obviously being most evident on otherwise shiny disc faces, but also forming on the actual brake pads too.  Take a close look at the edges of the pads if you doubt me.  :tongue:
Give your discs and calipers a thorough rinse with a jet wash (obviously being sensible about not being too close), and the rusty discs should be reduced.  Also, next time you remove your wheels, put a thin smear of anti-seize paste on the mounting face, and the centering hub of the wheel mount, and a smear on the wheel bolt threads and conical face - and this will massively prevent galvanic corrosion.  :nerd:  :smug:
I feel like a homo
Offline RedRobin
« Reply #26 on: 05 September 2008, 19:32 »
....Ah TT, that goes some way to explain why my discs don't get rusty - I usually jet wash before handwashing and always jet wash the wheels a bit more strongly than the rest. Makes handwashing so much easier too.
NewGolf
« Reply #27 on: 05 September 2008, 19:36 »
Copper Slip ok?
Offline Top Cat
« Reply #28 on: 05 September 2008, 19:37 »
TT you truly are:
  galvanic corrosion.  :grin: :grin: :grin: :grin:
Offline SteveP
« Reply #29 on: 05 September 2008, 20:02 »
Thanks for tips T_T  :smiley: :cool:
