Author Topic: Header tank  (Read 1230 times)
Offline AnniversaryWul
Header tank
« on: 03 September 2008, 10:58 »
Got the coolant warning coming on nearly everytime i start the engine now. Coolant level is fine and if you stop and start the engine it goes away. Gonna have to buy a new header tank  :sad: Is this easy to fit? i imagine it is, but anyone got a guide?
Offline ben1.8T
Re: Header tank
« Reply #1 on: 03 September 2008, 11:19 »
Should be fairly easy mate.  :smiley:
Golf SOLD. Replaced with a Yamaha Raptor 660 quad and loving it. This will be replaced in August with a Raptor 700. Sold the quad now got a Vectra GSI 2.5 V6 and its the nuts.
Brands Hatch massive. MEMBERSHIP ACCEPTED!
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: Header tank
« Reply #2 on: 03 September 2008, 14:15 »
No guide, mate, but all you need is a phillips screwdriver & a pair of pliers, IIRC (it's been a while since I did mine, TBH).
1) Undo the 2 screws
2) Unplug the top sensor - release the cable from the side of the tank
3) Unclip the top hose - release the cable from the side of the tank
4) This is the tricky bit & you have to work fast, LOL.  You have to take the bottom clip off, but be ready to pull the tank up & turn it on it's side QUICKLY to minimise the coolant spillage.
There maybe better ways out there, but I only lost a few drops.  :wink:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline RichGtiT
Re: Header tank
« Reply #3 on: 03 September 2008, 14:42 »
i did this a couple of months ago, really simple job. Found it was easier to drain the coolant first rather than trying to not spill it everywhere.... (from the tap at the bottom right of the radiator). Plus you get to put brand new G12 back in for good measures (only about £10 from dealers i think)  :grin:
hope that helps :)
