Author Topic: Cam belt / Cam chain?????  (Read 2746 times)
Offline AnniversaryWul
« on: 03 September 2008, 10:39 »
Was just having a look about vagparts and seen a timing chain for the auq engine. (got an anni)
I thought it was a cam belt it had as i just had it in to get the cambelt and waterpump replaced. Anyone got any ideas? Only engine ive stripped down and built back up was a saxo 1.6 8v so it was probably a bit different, not even looked under the engine cover of the 20v
Offline GTi-Matt
Re: Cam belt / Cam chain?????
« Reply #1 on: 03 September 2008, 10:43 »
im with u on that mate i thought the were all belts and chains were only used on rotary engines eg rx-7
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
« Reply #2 on: 03 September 2008, 10:56 »
Im puzzled.  :huh: :huh: :huh: :shocked: :undecided: Toyota use the chains as well as they are a lot more reliable than a belt and seldom ever need changed as they are kept lubricated by the engine oil in a sealed compartment as far as i know. When i got the anni back from getting the timing belt done the invoice had the part numbers and price for the cambelt kit. Then i seen on vagparts the chain is for the auq engine???
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #3 on: 03 September 2008, 13:16 »
Some old Fords (Sierra's IIRC) used to use chains.
http://www.vwspeed.co.uk/volkswagen/vw-parts/1_8T_Genuine_Cambelt_Kit-2234-321.html
Don't forget you need to get tensioners & water pump done at the same time. :wink:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline J5H VW
« Reply #4 on: 03 September 2008, 13:40 »
I think many cars use chains (mainly bigger engine german marques, like V12 BMWs and Merc etc.)
From my knowlege, all golfs use belts - but for some reason, i think the VR6 might not....but then I am sure that will be corrected by someone.
2001 VW 1.8t Golf GTi 5 Door (AUM). Xenons, Heated Black Recaro Leather, Front Arm Rest, Stubby Alloy Bee-sting, Climatronic, Heated Washers, Headlamp Jets, Touareg Torch...and a fire extinguisher should it all go wrong! - NOW SOLD
2005 BMW 330cd M Sport Convertible - Sparlking Graphite, Full Electric and Heated Red Leathers, TV, Nav, Bluetooth, Active Xenons, Wind Diffuser
« Reply #5 on: 03 September 2008, 13:52 »
Offline dai-cymru
  • 1989 MK2 16V
« Reply #6 on: 03 September 2008, 17:17 »
it's not a timing chain, you have a timing belt (cam belt) and a camshaft chain which is what your looking at, the cam chain is for DOHC (Double Over Head Cam) models and has a chain and tensioner to link the 2 cams together.  not just big german cars that have timing chains my 1993 mini cooper had one he he :smiley:
