Author Topic: Will R32 rear brakes fit the ed30?  (Read 30890 times)
Offline Hurdy
Re: Will R32 rear brakes fit the ed30?
« Reply #30 on: 01 September 2008, 19:10 »
Are the R32 rears,GTI front brakes then? If you get what I mean?
Which was what I was going to ask. Will my GTI fronts fit on the rear or do I need to replace all the other parts too (as in the R32 conversion)?
Seat Leon Cupra Black 290 DSG
Offline Teutonic_Tamer
« Reply #31 on: 01 September 2008, 19:31 »
I think I get your question - but no is the answer.
The front wheel drive GTI / Edition30 / Seat Leon Cupra / Å koda Octavia vRS (all from the PQ35 platform) all use identical specification rear brakes, being solid discs, 286mm diameter by 12mm thick.  They are clamped by a Lucas/TRW CII38HR-A caliper, with a piston bore of 38mm.
Whereas on the identical platform four wheel drives such as the R32 and the S3, the disc is a centrally ventilated one (just like the fronts), and is 310mm in diameter by 22mm thick.  A different type of Lucas/TRW caliper is used, namely a CII41HR-A - I'll let you guess the piston size!
Now, on the "lesser" 4motion models, such as the Golf TDI 4motion, the caliper is the same CII41, but the disc diameter is both smaller, and non ventilated.
I feel like a homo
« Reply #32 on: 01 September 2008, 19:35 »
Huh, maybe I did mis-understand TagnuTs question!  :embarassed:
So, to that - NO front brakes are interchangable with any rear brakes - at all.  :nerd:
Unless you know of a Mk5 Golf which has the handbrake working on the front wheels!  :rolleyes:  :grin:
I feel like a homo
Offline TagnuT
  • Edition 30
« Reply #33 on: 01 September 2008, 19:40 »
ok, forgot about the handbrake  :rolleyes: Just that the shape looked similar.  :smiley:
Bye Bye Edition 30
Offline k4ith
« Reply #34 on: 01 September 2008, 20:07 »
I bought the front R32 set up of ebay some time ago for £205 of ebay, reason being the Seat and VW dealers want dif prices for essentialy the same parts.
VW R32 Part no's
LH Calliper: 1K0 615 123J - £161.63
RH Calliper: 1K0 615 124J - £161.63
Carriers: 1K0 615 125F - £119.10 each
Seat Cupra Part no's
LH Calliper: 1K0 615 123K - £109.32
RH Calliper: 1K0 615 124K - £109.32
Carriers: 1K0 615 125G - £146.05 each
Vw parts has the r32 set up for sale for £650 all in incl delivery.
I painted mine but didnt like the look so got them powder coated instead
« Last Edit: 01 September 2008, 20:13 by k4ith »
MKV Golf GTI Edition30, GIAC Pump&Race Map, AutoTech Fuel Pump, R32 Front Brakes, Dbilas Flo-master Intake, S3 Intercooler.ECS Dog Bone Insert.
MKII GTI 8v Tornado Red 88 - Das Projekt
Offline K1
« Reply #35 on: 01 September 2008, 20:18 »
don't have any clearer pics. but the rear discs are about the same diameter as the stock gti fronts. Also the caliper is alot bigger than the stock rears.
White Edition 30. Born 26th/June/2007. Highline, Xenons, IPOD+Armrest, Cruise Control. Dbilas intake, Forge short shift, GIAC fuel maps, Forge DV, Milltek Non-res Turbo back, Eibach pro damper, pro kit and anti roll bars. Black Monzas, Kenwood DNX5220BT, R32 Front n rear brakes
Offline luca
« Reply #36 on: 01 September 2008, 20:30 »
My mate works for vw and said he can get the r32 brakes at cost +10%. Will see what price he comes up with, if i dont get the ebay ones.
K4ith how much did it cost to powder coat the calipers? Where did you get them done?
Golf gti ed30, tornado red, itg panel filter, revo stg 2, team dynamics gloss black wheels, turbo back milltek, ecs dogbone mount, leon cupra brakes. s3 intercooler ordered.
« Reply #37 on: 01 September 2008, 20:45 »
And are they ventilated?
Yes, it may be visibly bigger than the GTI rear caliper, but it is fundamentally the same rear caliper design, with the same handbrake operation!
I feel like a homo
Offline k4ith
« Reply #38 on: 01 September 2008, 20:49 »
I had to strip the piston section from the calliper which is just big bolts i think.But it was £60 for the 2 callipers and carriers.Its was local company where i worked in Livingston.
Offline k4ith
« Reply #39 on: 01 September 2008, 20:50 »
T/T here's a pic of what the disc looks like, note the badly spayed hub/bell lol.
