Author Topic: removing spoiler  (Read 1765 times)
Offline Benny T
removing spoiler
« on: 31 August 2008, 18:04 »
Thinkin of removing the rear spoiler off my gti for the auro look. Does it just pull off or is it through the glass?
Ta
Offline bobbito
  • Hammer and Chisel Engineering
Re: removing spoiler
« Reply #1 on: 31 August 2008, 18:15 »
Its bolted through and mastic on the back of it. You need to get some rubber grommets to fill holes or replace with gl/cl glass.
Offline snifferdog
« Reply #2 on: 31 August 2008, 21:30 »
yeah its a 2 minute job,3 bolts on the back i think.probably be easiest to just get some grommets for the holes! :wink:
Offline Mikester
  • Civic Type R
« Reply #3 on: 31 August 2008, 21:34 »
3 bolts, job done. grommits from halfrauds or other places.
Im going to take mine off to spray soon :D
« Reply #4 on: 31 August 2008, 22:02 »
Just for info, mine had small covers over the nuts which are the correct size to blank the holes.
kells
« Reply #5 on: 31 August 2008, 22:27 »
be carefull tho if you use those as they aint propper grommets, they are just caps and may leak water in
« Reply #6 on: 31 August 2008, 23:58 »
That could be why I have water in my boot most times that it rains then, cheers for the info will get some proper gromets asap.
Offline bored_Welsh_lad
« Reply #7 on: 01 September 2008, 14:16 »
They fit fine, ive ran them on my boot for a yr now and not had any issues whatsoever...
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
kells
« Reply #8 on: 01 September 2008, 18:14 »
your lucky then, they aint propper grommets, they wont seal correct no matter what, just use the propper thing, they cost pence
Offline RiCHiE360
« Reply #9 on: 01 September 2008, 19:08 »
They may be "ok" but for the sakes of a quid you can have properly sealing gromits that sit flush with the glass, not big black nipples stickin out  :grin:
Roofless VR6 FTW
