Author Topic: 16v wiring ...  (Read 736 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
16v wiring ...
« on: 30 August 2008, 22:40 »
in the process of wiring up the 16v engine into the 1.4   All is going well half of the plugs are in the fuse box now but there is alot of little colourd loose ones and i know a few are just left loose for other things to connect in but i cant for the life of me remeber which ones.
Does any one know of a good wiring diagram for the dash loom/fuse box etc..?
cheers.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline saul79
Re: 16v wiring ...
« Reply #1 on: 31 August 2008, 19:30 »
the single wires with the little plugs on  blue ones go in a 4 pinned plug holder and the brown in brown and grey ones in grey  .Its a rectangle shaped holder above the relay plate
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
