Author Topic: Clutch Problems - URGENT  (Read 832 times)
Offline K16-MYK
« on: 30 August 2008, 16:19 »
Earlier today i went to press the clutch pedal, and itr went down, but too far! The little clip at the bottom of the control arm that cradles the cable, had snapped. Managed to get car home no bother. Got the clip fitted ok. Now there is no drive in the gears. Is there a way to adjust the cable? Any help want Urgently, cheers.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Clutch Problems - URGENT
« Reply #1 on: 30 August 2008, 16:58 »
it take it the clutch is not engaging?  should be an auto adjuster on yours?  in which case these tend to lock up. the only thing you can do is replace it.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 30 August 2008, 16:59 »
its a common fault for pieces to fall off the clutch peadal ir arm....and it does kill the cable!! as said you'll need a new one
Offline K16-MYK
« Reply #3 on: 31 August 2008, 14:51 »
Cheers lads, did a bi of investigating last night :shocked: I ended up opening up the auto adjuster and temporarily repairing it til tomorrow til i can get a new cable :grin: Runnin ok for now Anyhoo :wink:
