Author Topic: wat a waste of fcing time now sorted (now with pics)  (Read 44214 times)
Offline leeroy20vt
  • h reg mk2 gti
got up to the garage by 8am this morning to put me new springs on done it all drove out of the garage at 10am and they havent lowered the car in the slightist wat a waste of time im well p!ssed off  :cry: :cry: :cry:
« Last Edit: 04 September 2008, 18:49 by leeroy20vt »
Offline the_stink
  • A3 140 TDI
Re: wat a waste of fcing time
« Reply #1 on: 30 August 2008, 12:37 »
dont the springs take a while to settle?  :undecided:
Offline leeroy20vt
  • h reg mk2 gti
« Reply #2 on: 30 August 2008, 15:32 »
yer thought so but surely u would see a difference straight away
Offline Rhyso
« Reply #3 on: 30 August 2008, 16:07 »
did you have lowering springs on to begin with??  :undecided:
don't forget your car is lower than standard anyway so you may only see a 15-20mm drop  :sad:
Offline leeroy20vt
  • h reg mk2 gti
« Reply #4 on: 30 August 2008, 16:12 »
na bog standard gti springs m8 i measured gap befor i pu then on and after both came out 60mm gap so i dunno goin to  :cry:
Offline Rhyso
« Reply #5 on: 30 August 2008, 16:20 »
you deffo been sent the correct springs?
yours will take some time to settle being brand new - mine dropped a) used b) huge big powerful derv engine in the front  :tongue:
Offline leeroy20vt
  • h reg mk2 gti
« Reply #6 on: 30 August 2008, 18:18 »
i got the part number of the box if that any help
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #7 on: 30 August 2008, 18:20 »
The car in your sig looks lowered to me??  :undecided:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline leeroy20vt
  • h reg mk2 gti
« Reply #8 on: 30 August 2008, 18:27 »
photoshop m8 soz
Offline dai-cymru
  • 1989 MK2 16V
« Reply #9 on: 30 August 2008, 19:12 »
have you made sure the springs are correctly seated in the strut ( i.e spring in it's cup) you should see a difference straight off but wont see full drop until settled. also are the strut's fully in the hubs so that the hook for the pinch bolt is correctly located?
