Author Topic: tdi problem boosting  (Read 2193 times)
Offline *tell*
« on: 26 August 2008, 22:35 »
 if have got myself a tdi estate  :sick:
have had a code come up of 00575.
i have replaced all vacum tube and the n75 valve.
cleared the code after try all off these but the problems still there.
it a 1z engine code and it done 150 000 miles.
if your on the motorway going up a hill it will stop boosting at 60 and on the
flat at 75?
 :undecided:
thanks tell
Offline saul79
Re: tdi problem boosting
« Reply #1 on: 27 August 2008, 21:43 »
check to see if the wastegate is seized it wont boost if its seized try tapping the arm off it and see if it frees off .When you rev it is should move freely if it dont its turbo time
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline *tell*
« Reply #2 on: 28 August 2008, 21:07 »
cool will give this a go never own a turbo'd car (diesel  :sick:)
 :smiley:
Offline scoobydoo
« Reply #3 on: 21 July 2009, 23:33 »
did you have any luck with this - i have similar problem
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #4 on: 22 July 2009, 17:55 »
Same problem ere,   Common too!   Ther are a few things to try.
You say you replaced the pressure hoses,  Check the one that comes off the intake manifold pipe to the ECU (it actually goes inside the ECU)  Also if thats ok there is a small stretch of pipe inside the actuall ECU that can wear out, replace that too.
Other than that im not to sure.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
