Author Topic: CAR BROKE  (Read 2474 times)
DOCKERMEL
CAR BROKE
« on: 22 August 2008, 21:13 »
help on me way home my car kept cutting out. it stopped all together,it starts first time but then dies.. any help mk3 8v gti.. thx
Offline 95gtipete
Re: CAR BROKE
« Reply #1 on: 25 August 2008, 21:50 »
Throttle body
DOCKERMEL
Re: CAR BROKE
« Reply #2 on: 26 August 2008, 09:30 »
stupid car. went back to it about an hour later it went fine. drove it home replaced the coil,rotor arm and dizzy cap. went for a drive it still keeps cutting out. any ideas. :sick:
Offline Dan34
  • VTEC Powerzzzz
Re: CAR BROKE
« Reply #3 on: 26 August 2008, 10:22 »
clean out the throttle body that should sort it
Rob Needham
Re: CAR BROKE
« Reply #4 on: 26 August 2008, 11:15 »
i had exactly the same problem and was the lambda probe, who knows tho could be many things....Vag-com, only way to know for sure!
kells
Re: CAR BROKE
« Reply #5 on: 26 August 2008, 13:44 »
sounds more like the usual relay fault if you ask me, and possibly faulty ignition switch is another thing it could be
Offline Guy
Re: CAR BROKE
« Reply #6 on: 26 August 2008, 13:47 »
ignition switch would just be no sparky at all... would it not?
kells
Re: CAR BROKE
« Reply #7 on: 26 August 2008, 14:00 »
nope...
its exactly the symptoms of what mine did, intermittant working and genrally just pissing me off, if you messed with the wires on the back of the switch it would run, it also would run if you held the key on as far as you could
common fault on the 3 is the ignition switch, changed mine and its now fine (did this after changing all the bleedin relays)
Offline Guy
Re: CAR BROKE
« Reply #8 on: 26 August 2008, 14:05 »
nope...
my ignition switch worked fine on my journey to the supermarket... then when i finished my shopping it was dead and wouldn't start at all
that was annoying
DOCKERMEL
Re: CAR BROKE
« Reply #9 on: 26 August 2008, 15:54 »
ok where is the thottle body and how do i clean it??  thx any idea which relay, will try all the cheap fixes first.
