Author Topic: clutch cable to hydraulic clutch (mk3)  (Read 5086 times)
Re: clutch cable to hydraulic clutch (mk3)
« Reply #10 on: 22 August 2008, 10:41 »
I think he means the actual plastic reservoir?  If so look for a Corrado one or earlier Passat, I'm pretty sure they had models with a cable gearbox but no ABS.  If not then bleed nipples aye, also usefull as you can bleed the master cylinder like a caliper after  :grin:
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #11 on: 24 August 2008, 08:54 »
Yea i mean the plastic tank.  Im using the 1.4 master cylinder.   It looks the same as the one off my non ABS Gti.   If not i will use the GTI one.   Just looks alot older.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
