Author Topic: Overheating....fan not working  (Read 12276 times)
Offline J5H VW
Re: Overheating....fan not working
« Reply #10 on: 19 August 2008, 13:17 »
Maverick, thats what I am thinking the issue it - the switch (if one exists) that kicks the fans in at a certain coolant temp.
I just went and did a few more check over lunch.  Guys take a look and let me know if you dont agree with that I have done/ what i beleive based on what i have done.
1. The Water Pump
To attempt to check this, I removed the coolant tank lid and started the engine.  I can see coolant flowing back into the tank from the top hose when the car idles.  I assume this shows that the pump is still working....so Water Pump is OK.
2. The Radiator
Next I wanted to check coolant was flowing round the whole system, and through the radiator.  I let the car warm up and then touched the hose to the top right hand side (near the battery), as you look at the engine from the front of the car.  I believe this to be the inlet to the radiator.  It was now warm, so I assume coolant is flowing that far at least.  To check it is coming out the other end of the radiator, i couldnt figure out which hose was the outlet, but the hose which feeds back into the expansion tank is now hot too (same one I used in checking the water pump).  Given these two hoses are now hot, I assume the water is circulating right the way round the system, through the radiator.
3. The Fans
Next I need to check if the fans are working.  I know they come on wtih the air con compressor, and run at low speed.  My compressor has packed up, but I still turned the climate control such that it should be running.  The fans are not running.
So...now...is there a fan switch, which causes the fan to kick in at a certain coolant temp?  Where is this and how can I check it?  I am pretty sure the fans are not broken, and it seems coincidental that I notice the overheat as soon as the compressor packs up and fans stop spinning.
2001 VW 1.8t Golf GTi 5 Door (AUM). Xenons, Heated Black Recaro Leather, Front Arm Rest, Stubby Alloy Bee-sting, Climatronic, Heated Washers, Headlamp Jets, Touareg Torch...and a fire extinguisher should it all go wrong! - NOW SOLD
2005 BMW 330cd M Sport Convertible - Sparlking Graphite, Full Electric and Heated Red Leathers, TV, Nav, Bluetooth, Active Xenons, Wind Diffuser
Offline dai-cymru
  • 1989 MK2 16V
« Reply #11 on: 19 August 2008, 19:40 »
should have felt the bottom radiator house to see if the coolant is circulating. there is a thermostaic swith in the radiator on most cars you can bridge the 2 wires out and the fan will come on. if it doesnt you got a electrical fault to the fan, if it does the thermostaic switch is stuffed. i think the golf has a 3 pin switch so not sure which wires you need to bridge out. would need a wiring diagram from a haynes manual.
Offline J5H VW
« Reply #12 on: 19 August 2008, 21:15 »
Managed to find a local garage that was able check out the fan for me.  Seems it the switch.  Having it replaced tomorrow, so will see if it all works!
Cheers for all the help guys.
Offline Saffa
« Reply #13 on: 19 August 2008, 21:47 »
Hi,
The air con will not work if the cooling fans or fan e.c.u has a fault, as the fan e.c.u also controls the air con compressor clutch.
On top of your battery is a fuse box, check ALL the fuses including the green 30 amp ones for dirty or burn't connectons as it is very common for this to burn out.
If it is burn't , you will need to change the fuse box assembly, not expensive, these fuses supply the fan e.c.u which then supplys the fans and air con.
Hope this helps?
Jochen.
Offline Ashmond
  • Money, b!tches And Boost
« Reply #14 on: 20 August 2008, 09:06 »
Get the triangle temp sensor off the rad and bridge two of the connections, do it one way and you'l get it on high fans and another on low, make sure you use thick wire as I did it and it melted it, then electrical tape the wires in, to turn it on and off take out the green fuse on the far left of you fuse bozx on top of your battery.
I got this problem too and it turns out that I need a new water pump fitted but it could also be the following: thermostat (get a 70 degree one instead), air lock in the system, empty all water and refill with coolant or the actual temp switch in the rad is knackered.
Any problems let me know as I am dealing with this atm on my motor.
Ashmond
Offline J5H VW
« Reply #15 on: 20 August 2008, 12:24 »
cheers for all the help guys.
The garage is replacing the temp sensor/switch on teh radiator today.  Will see if that solves it.  i think it a common thing for them to corrode from what i have heard.
Also, Jochen, it makes sense now that the air con compressor wont kick in since the fan switch is screwed.
Will keep you all posted on progress, collecting it after work - when it should have a new MOT too!
Offline euroscot
« Reply #16 on: 20 August 2008, 12:28 »
I had 2 corsa's that were bad for this. It was the sensor called the thermo switch which senses water temp. to tell the fans when to come on. Not sure what they are called on the golf but could be the sensor or a possibility that your fan motor has packed in but very much doubt it.
Offline J5H VW
« Reply #17 on: 20 August 2008, 12:54 »
I know the fan motors work, as both spin when supplied with power (as applied with the switch removed).  hence it suggests its the switch that is at fault.
Offline dai-cymru
  • 1989 MK2 16V
« Reply #18 on: 20 August 2008, 13:13 »
yep defo switch nice cheap repair for you :laugh:
Offline J5H VW
« Reply #19 on: 20 August 2008, 16:32 »
Garage called me.  Still not too bad!
The swtich had to be replaced.  But also there is a fan control unit/relay under the battery.  That needed a good clean up (im guessing of the contacts etc).
Finally, a fuse above the battery had melted (though not blown).  This had to be replaced too.
So all in all, turns out not too bad.  not sure why the fuse started to melt rather than blow - will need to watch this one.  Will check it out when I pick the car up.
