Author Topic: Broken  (Read 13816 times)
Offline dai-cymru
  • 1989 MK2 16V
Re: Broken
« Reply #10 on: 16 August 2008, 21:52 »
if you got a meter put it across battery and get someone to crank it over if it drops really low (which it will by the sounds of it) you know it's battery. hard to check alternator without it running need to jump start it put the meter across it when running then (take jump leads off) should be charging 13.5v to 14.5v approx any lower and it's not charging if your getting that then the battery is stuffed and not holding charge. :sad:
Offline richw911
Re: Broken
« Reply #11 on: 16 August 2008, 21:53 »
Yeah defo try that, Also check the earth strap from the batt to the body could well be corroded  :smiley:
Offline dai-cymru
  • 1989 MK2 16V
Re: Broken
« Reply #12 on: 16 August 2008, 21:54 »
sounds like bad previos repair, perhaps not getting good contact at at that fuse connection
Offline T_J_G
Re: Broken
« Reply #13 on: 16 August 2008, 21:56 »
But waht I posted last time would make sense. Alternator not getting power to charge the battery. I'm not very good with engines and electrics just working to rule things out.
Apparently the car only needs the battery to start, in that case, mine started ok to drive, then the alternator wouldn't support the power needed and therefore the loss of power. This could be caused by that cable I posted which wouldn't let the alternator function. :undecided:
I shall get a picture in the morning.
Offline T_J_G
Re: Broken
« Reply #14 on: 16 August 2008, 21:57 »
Maybe so.
Offline T_J_G
Re: Broken
« Reply #15 on: 16 August 2008, 22:17 »
I wonder where that black cable comes from or if it's part of the loom?
Tim
Offline T_J_G
Re: Broken
« Reply #16 on: 17 August 2008, 10:27 »
Still won't start  :angry:
May go and buy a new battery and a multimeter to check alternator.
kcolevol
Re: Broken
« Reply #17 on: 17 August 2008, 10:49 »
I had this happen to me!! see if your car starts with a jump, if it does, then its the battery, i had mine go with no warning at all, got a new battery and its been fine for 3 months now!!!
Offline T_J_G
Re: Broken
« Reply #18 on: 17 August 2008, 10:55 »
It's going back to the garage on Tuesday as they'll contribute half to the battery as part of the warranty.
They can find the fault and repair it.
Offline leeroy20vt
  • h reg mk2 gti
Re: Broken
« Reply #19 on: 17 August 2008, 10:58 »
m8 u aint havin much luck with this r u hope u get it sorted m8 poxy cars huh
