Author Topic: ITS OFFICIAL  (Read 4625 times)
Offline jasonpi
ITS OFFICIAL
« on: 04 May 2004, 20:39 »
i need more power, so im thinking of a turbo! all the usual questions what turbo to use what needs doing to the engine etc etc and will i benefit
Offline Dizzie
  • Make friends with your fast
Re:ITS OFFICIAL
« Reply #1 on: 04 May 2004, 21:49 »
I've heard a T2 turbo and manifold from a mk3 does the trick. you'll need to lower the compression if you're running high boost or what to get a large increase in power from it.
Not sure what you'll have to do about the injection system though.
Offline Zoid
Re:ITS OFFICIAL
« Reply #2 on: 04 May 2004, 22:28 »
Hey Dizzie according to your signature it looks like you've had the conversion done on your 8v to 20v Turbo? I'm really interested on how it went, the results, good points, bad points etc.....  :)
Offline Dizzie
Re:ITS OFFICIAL
« Reply #3 on: 04 May 2004, 23:22 »
it's off on next tuesday to be done. I'll see if they don't mind taking pics when I give them the car. the longest 2 weeks ever begin soon :(
sorry to hijack the tread. back to turboing the 8v...
marcus123
Re:ITS OFFICIAL
« Reply #4 on: 05 May 2004, 08:34 »
hey dizzie,
so is yours a 1.8t or not?
golfvr6
Re:ITS OFFICIAL
« Reply #5 on: 05 May 2004, 08:50 »
I wouldn't bother putting a turbo on an 8v, put a g60 or 1.8T lump in instead.
G60 lump should be fairly straightfoward, and not too expensive. 1.8T is better and more tunable, but will cost a lot more.
Offline jasonpi
Re:ITS OFFICIAL
« Reply #6 on: 05 May 2004, 09:31 »
so if i go for a g60 lump is it a straightforward swap? 1.8t is too common
marcus123
Re:ITS OFFICIAL
« Reply #7 on: 05 May 2004, 10:03 »
im doing a g60 swap( when i get the money) ;)
and they are complicated and far from straight forward!
ive been quoted ?500 to do the conversion by a vw engineer that i know,
but all the professionals are quoting 5 to 7k!!!
but g60 is the conversion to do, 1.8ts are cool tho! :D
VeeDubGTI16v
Re:ITS OFFICIAL
« Reply #8 on: 05 May 2004, 10:35 »
who cares if an engine is common. its not a hat ffs. ;D
its common because its blatantly the best engine for tuning.
golfvr6
Re:ITS OFFICIAL
« Reply #9 on: 05 May 2004, 11:41 »
G60 shouldn't be too bad in a digifant, a k-jet would be a pain in the arse.
Of course no engine conversion is that straightforward, but G60 in digifant should be a lot easier than 1.8T conversion.
It all comes down to how much cash you have at the end of the day.
