Author Topic: KW Coilover  (Read 11902 times)
Offline Teutonic_Tamer
Re: KW Coilover
« Reply #10 on: 01 September 2008, 18:52 »
MR TT could i have your valued advice on this please i know bits aint going to fall off but i remember you mentioning about slight changes to the front of the aerodynamics affecting the dsg so in weighing up the pro's and con's of getting coilovers and lowering the car what long term affects will fitting these have.  :kiss:
Aerodynamics are a black art.  However, providing you don't modify the engine undertray, and you haven't fitted those :sick: open fog lamp grilles, then lowering, even upto say 40-50mm shouldn't affect the air flow under the car to the DSG.  However, if you go very, very low, whereby the front is nigh-on kissing the tarmac, or if you fit one of those stoooopid "max-power brigade" ultra low front splitters, then you create something called "ground effect" - which will be very bad news for the DSG, because ground effect is basically a "venturi" effect, and the air flow will actually accelerate under the car, and will actually miss being scooped up by the DSG and front brake cooling ducts.
So no open fog grilles, and no riding on the bump stops, and your DSG will be happy!
I feel like a homo
Offline Top Cat
Re: KW Coilover
« Reply #11 on: 01 September 2008, 18:58 »
Thanks TT
Re: KW Coilover
« Reply #12 on: 01 September 2008, 19:03 »
nobody has experienced that aerodynamic thing i dont think, i believe its TTs theory  :smiley: :smiley:
Huh - how do you explain all the failed mechatronics units which the Yanks seem to suffer?  Show me a Yank who has a perfectly standard car with a failed mechatronics unit!
Sadly, all the Yanks think its "cool", or dare I use Yankie terminology "sick", to lower their cars, fit those stooopid open fog grilles, and a plethora of other mods - virtually as soon as the car has left the dealers forcourt.
The DSG mechatronics unit is a heat sensitive component.  Saying that, Volkswagen will have no doubt spent many hours in the wind tunnel with the smoke wand, bits of string and sticky back plastic - along with considerable hours testing ranging from the Norwegian Arctic to some feckin hot desert somewhere - and deemed that the standard areodynamic profile of the Golf, including the GTI and R32, provide the correct amount of cooling to the correct locations of the cars critical parts, such as the brakes and the DSG.  I don't think the average Yank will be able to match VWs test programme, do you?
I feel like a homo
Re: KW Coilover
« Reply #13 on: 01 September 2008, 19:05 »
certainly was :smiley:
Well - what exactly did you need to do?  Just remove the screw and plastic speed nut, or bend up the flange, or sommat else?  :smiley:
I feel like a homo
Offline gazbutmk5gti
Re: KW Coilover
« Reply #14 on: 01 September 2008, 19:08 »
I removed the screw, plastic insert, bent the tab up a bit carefully as to not crack the paint. Then I tucked the liner behind the tab, I used a clip-nut from work on the liner then re-installed the screw
Revo stg2+ & lots more
Offline RedRobin
Re: KW Coilover
« Reply #15 on: 01 September 2008, 19:31 »
....I'm not 100% in agreement with you on this either, TT. I don't debate what VW have spent hours testing and developing but I think that the fog grills being 'open' are probably not enough to upset the DSG system as much as I understand you to be saying. For a start, one of them is blanked off just behind the open honeycombe, and the other is partially blocked off.
But I do understand that you are describing a downside of a combination of several aftermarket components.
Weren't the fog vents open originally by VW to gain extra cooling to the DSG but then found not to be needed and subsequently dropped to streamline the economics of production between DSG and non-DSG cars?
My Mechatronics Module failed at about 6k miles and well before I changed to 'open' fog grilles. I'm not at 52k miles and have had 'open' vents for at least 25,000 miles without any problems.
Re: KW Coilover
« Reply #16 on: 01 September 2008, 23:27 »
Oh boy.  Its a shame the forum crashed a while back!  :sad:
Look, in the original "pre-production" models released to the press, the GTI had "open" fog grilles - on both sides, like this:
However, after a very small number of the initial production GTIs which were released with those grilles, all future production GTIs had fully closed grilles.  So why, then, did VW feel the need to modify a part during a production run?  :rolleyes:  Cost - not really, asthetics - nope - so it must only be down to the performance of the individual part.  :smug:
Even on the higher output Ed30/Pirelli models - and therefore hotter running - VW still use the fully closed grilles:  :nerd:
So, by using your logic RR that these "open" grilles don't upset the airflow, particularly to the DSG - why then did VW change them to fully closed versions.  :rolleyes:
And you are wrong about these fully "open" grilles.  Yes, agreed that the one on the right is actually blocked off (however, most owners, particularly the yanks will dremel off the rear cover, and merely freeze solid their screen wash bottle in the winter!), but the right one is most definately fully open.  This was officially designed by VW for a "tropical climate" market - specifically Mexico and South Africa, and its purpose is to duct air to an additional large radiator behind the left fog light.  However, even with the supposed substantial additional cooling from this additional radiator (which is about a third of the size of the main rad) - this "tropical climate" spec was never fitted to any cars (in South Africa, Mexico, or any other "hot" locations, such as Dubai or Arizona), because again, the supposed benefits from this additional radiator were either (a) not worth while, or (b) actually detracted from the cooling of other items.  Now, unless anyone here actually works in the R&D at Wolfsburg, we will never know the real answer.  :lipsrsealed:  :rolleyes:
Now, going back to aerodynamics, you really do need to get a handle on the basics, and sadly, you don't appear to have any real grasp on the basic fundamentals of aerodynamics.  :smiley:  :smiley:  :smiley:  :smiley:
OK.  :smiley:
Nope, they were designed to provide additional cooling primarilly for the engine coolant - and for non-DSG cars too.  The internal ducting for these open grilles actually angles away from the DSG, in an orienation manner as though it was venting out of the side of the car.  The simple fact that the wheel arch liner is no longer available with the exit louvres for this rad must show how ineffective the whole system was, and maybe how it was starving the actual DSG of air?
OK, it could losely be argued that the DSG might also benefit, soley on the grounds that the DSG oil (along with the engine oil, and the turbocharger) also take a feed from the engine coolant.  However, their cooling benefit is of considerably less when compared to the engines own requirement - which would also explain why this is not used in hot climes.  :nerd:
And . . . there is no logic to that statment.  You can not "prove a negative".  It uses the same misguided reasoning such as:  If Fred Smith was to drive along UK motorways for a whole year at a constant speed of 120mph, and not get nicked - then 120mph is legal for a UK motorway!  :rolleyes:
Negative logic is very bad logic - which probably explains why politicians use it so much.  Unfortunately, negative logic proves Jack Schit!  Sorry to be so blunt!  :smiley:
I feel like a homo
Offline neg
Re: KW Coilover
« Reply #17 on: 01 September 2008, 23:44 »
If you want something for comform but looks better and improved handling - take a look at the Koni FSD's and some better spring (H&R) which is what I did - cheaper, gives the car a great stance and spot on ride comfort.
Offline RedRobin
Re: KW Coilover
« Reply #18 on: 02 September 2008, 00:06 »
....Agreed - I find the KoniFSD's plus Eibach springs and ARB's excellent for fast road use and several specialists have advised that this suspension is more than adequate unless I want to start doing regular track days and therefore go a stage further. Then Bilstein would be the best and KW V3's a second choice.
At the risk of making myself unpopular here, what I see is quite a few youngsters simply chasing the cool look of a lowered suspension and not really considering the full setup. And of course the likes of Awesome and Toys for Boys (and TTshop!) are more than happy to sell the gear. Coilovers are flavour of the month.
How many of you with track-style lowered suspension actually do track? Some yes, but a lot who don't.
But, each to their own.
[Prepares for lots of incoming flak]
« Last Edit: 02 September 2008, 00:10 by RedRobin »
Offline RedRobin
Re: KW Coilover
« Reply #19 on: 02 September 2008, 00:14 »
..Wrong thread!! Deleted
