Author Topic: boost?  (Read 2295 times)
Offline chloe18t
boost?
« on: 16 August 2008, 11:00 »
what is a safe boost to run with a standard turbo.  we have just purchased a turbo bleed valve. its running 5psi at the moment.
Offline Rhyso
Re: boost?
« Reply #1 on: 16 August 2008, 11:25 »
thought standard PSI was 8-9  :undecided:
a remap will take it to 15-18psi
Offline richw911
Re: boost?
« Reply #2 on: 16 August 2008, 13:17 »
True  :smiley:
Offline stealth_gti
Re: boost?
« Reply #3 on: 16 August 2008, 17:47 »
i just fitted a boost guage to check what mine boosted to and it boosts to 6 max. whats wrong??????
« Last Edit: 16 August 2008, 20:54 by stealth_gti »
2** Bhp, 2** Lb/ft , R-Tech map, FMIC, Forge CL007P, Powerflow Cat-back, 18" Tsw pace, Eibach -40mm springs, Pipercross induction kit, vr6 Clutch g60 flywheel
Offline jonnyturbo
Re: boost?
« Reply #4 on: 16 August 2008, 21:24 »
i would never use a bleed valve. Its rough. And its to tempting to keep turning the boost up and up. :smiley:
Offline richw911
Re: boost?
« Reply #5 on: 16 August 2008, 22:03 »
A boost guage is not 100% accurate BTW
Offline chloe18t
Re: boost?
« Reply #6 on: 18 August 2008, 13:15 »
we do have a boost guage. my boyfriend spoke to a mechanic and he said the safest is 6psi on a standard turbo. he wont keep turning the boost up, coz he doesnt want to damage the car, i think we will take it somewhere and have it all done proffessionly, thanks for your help :smiley:
Offline topher
  • Administrator
  • fully functioning
Re: boost?
« Reply #7 on: 18 August 2008, 13:42 »
Unless you want to be picking bits of engine out of your face after it explodes - bin the bleed valve. (Okay a little exaggerated but you get the point)
I managed to get mine spiking at 26 and holding 22/23 .. most remaps will give between 15 - 20 psi.
