Author Topic: Eibach coilies finally fitted!!  (Read 11522 times)
Offline joesgti
Re: Eibach coilies finally fitted!!
« Reply #20 on: 14 August 2008, 10:26 »
hurdy, id lower it a little more and then get it laser aligned, also you arse end looks higher than the front, leave it for 2 weeks to settle then adjust them so all gaps are the same under each arch and then get it laser aligned.  :cool: :cool:
GTI MK5
Not the only GTI...........but the best! ; )
Offline neg
« Reply #21 on: 14 August 2008, 11:07 »
Think I did well getting a mates garage to fit my lot for 100notes  :drool:
got a mate who will fit stuff for a pack of biscuits  :tongue:
I'll do it for half a pack - wont be that good mind you  :grin:
Offline Hurdy
« Reply #22 on: 14 August 2008, 14:24 »
When they did the final measure they took the distance from the bottom of the alloy to the rim of the wheel arch as the measurement and they were all the same.
They may settle a little as a few have said and I'll be keeping my tape handy :wink:
I went for a minimal drop at first to ensure the speed bumps, drive etc are all cleared easily. I can then get jiggy with the spanners to lower bit by bit until I'm happy. I don't want a rock hard ride and so slamming it is out (maybe for the odd show or two :rolleyes:)
Seat Leon Cupra Black 290 DSG
Offline Top Cat
« Reply #23 on: 14 August 2008, 16:44 »
I thought coilies had seperate dampening  :undecided:
Offline Top Cat
« Reply #24 on: 14 August 2008, 21:11 »
Just thought i'd bump this one back up i'm looking at getting some in the near future i thought coilover's advantage was that they had seperate dampening aswel as being easily adjustable or am i getting confused again.
Offline gazbutmk5gti
« Reply #25 on: 14 August 2008, 21:13 »
the ride height is adjustable but the damping is fixed pal
Revo stg2+ & lots more
Offline Rhyso
« Reply #26 on: 14 August 2008, 21:16 »
not sure of their advantage mind - i assume that they are obviously stiffer and react quicker in order to give better car control  :undecided:
Offline Hurdy
« Reply #27 on: 14 August 2008, 22:15 »
I'm sure that Bilsteins have independant adjustable damping with 9 settings :nerd:. PSS9's or maybe PSS10's I believe now :undecided:
Offline CocoPops
« Reply #28 on: 14 August 2008, 22:48 »
My sachs coilovers have 12 clicks of damper adjustment  :nerd:
2018 GTI Performance Pack DSG 5dr, Tornado Red, Leather, 18" Seville Wheels, DCC Suspension, Tints, RVC
2018 Lotus Elise Sport220
Previous : 1983 Mk1 Golf 1.1 & 2008 Mk5 Golf GTI Ed30
Offline Hurdy
« Reply #29 on: 14 August 2008, 23:17 »
They are the ones you won aren't they?
How are they?
